Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Sears kenmore vacuum 11624614400 will not start
I replaced the switch and obviously got it wrong. I need a wiring diagram for the switch and of course not I probably need a reset? for motor?
Could I have burned relay/ motor/fuze by installing switch wrong? How do I open motor compartment?
  • Anonymous Apr 08, 2009
    vacuum motor will not turn on , everything else works.
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Kenmore Vacuum model #116.25813508
In yours there is a pcb asm, #KC86WBZRZ000 , you probably need to replace it.
Posted on Sep 01, 2008
  • 6 Answers
SOURCE: Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Posted on Oct 26, 2008
How do I open a Panasonic Power Nozzle to replace the belt? The Vacuum Model # is MC-V9635
The top part of the nozzle pops off just put small screw driver on side and lift up under the top lid is 2 screws then pop off by putting screw driver on sides to lift the housing off base plate
here is roller
Sears Kenmore Brush Roller 8192670 8175102 And 742454
and roller
Sears Kenmore And Power Mate Canister Power Nozzle Belt Part 20 5285
Jul 05, 2014 | Panasonic Vacuums
Sears canister vacuum rear wheel won't stay on
1) test the power cord for open, defective, or break use the VOM
2) test the fuse for open, loose wire use the VOM
3( tes the motor, for open, short, or defective, need repair.
4)test the switch, for open, or loose wires, or short.
see how to do it.
God bless you
Jul 10, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuum will not turn on, the switch is ok. It
how do you know the switch is ok? it can go bad as fast as a light bulb. Sears sells kenmore vacuums,you con get a book from them.
Oct 18, 2009 | Kenmore Upright Vacuum Vacuum
VACUUM WON'T SHUT OFF
Most likely the pcb in the cannister is bad, part # KC86WBZRZ000
Sep 01, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Kenmore 116 Progressive Canister Won't Run
In the canister there is a fuse wire, also a circuit board that could be bad, I would check the fuse wire first. If the motor has a thermo protector on it, it may be open. The switch asm. in the hose handle could have gone bad.
You can to sears.com and click on the parts link, enter your model number, then scroll down, you can chose which page you want to look at. It will bring up a parts page, scroll down and you get a picture breakdown. You can also order parts thru the site.
May 27, 2008 | Vacuums
Kenmore vaccum cleaner
Switch number is 4369051 . You can go to sears.com, click on the parts link, put in the part number and you can order it thru them. Or put in you model number, click on dust compartment and a parts list and a picutre diagram will come up. You can order there also.
Mar 20, 2008 | Vacuums
Need a model number to be sure, but alot of the Sears cannisters have a relay and it is found mounted in the motor comparment, it may be sticking in the on position.
Nov 26, 2007 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore canister model 116.25512 won't start
Sounds like you have a switch problem. Some of the Sears models also have a relay in them, which could be bad. The complete model isn't stated so couldn't look it up. But you can go to Sears.com, click on parts, enter your complete model number and a parts list with diagram of parts will come up.
Oct 25, 2007 | Vacuums
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
521 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
