Dell Dimension 5150 cd-rom problem
Thanks for the suggestion. I'd rather not remove the case if I don't have to. I went into bios, some drives are enabled and some aren't. I don't know which one is the cd-rom drive. The list is Diskette Drive, Drive 0: SATA-0, Drive 1: SATA-2, Drive 2: PATA-0, Drive 3: PATA-1. How do I tell which one is the cd-rom drive?
  • 158 Answers
It's usually PATA-0. If you are finding trouble in finding it, u can open the case. You should see a small Battery seated on the motherboard. Remove it and and reseat it after 30 sec. This will reset the BIOS setting to default keeping all the devices enabled.
Please ensure power cables are unplugged while doing this.
Posted on Jan 09, 2009
Hi, I have downloaded from DELL website the Dell Dimension 5150 BIOS to upgrade the BIOS. I followed all the steps successfully and restarted the system but it just showed incompatible BIOS on start-up....
first to get a properly bios you need to get the whole description and download it to an floppy disk if it does if not try to boot from a cd...theres a hirens boot cd tools to fix since you already flashed wrong i assume you have some experience use the key tag of yor dell to get properly drivers...
May 27, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Max hard drive that can be fitted to a dell dimension 5150 thanks tom
Sir your Dell dimension 5150 can be expanded with maximum 250 GB of hard drive .
Thanks.
Have great day.
Oct 10, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I can't access my two CD Rom drives on this Dell 5150. I find them displayed in the hardware list of the Device Manager but NOT when looking My Computer. I installed Roxio Creator which screwed up my...
If windows is recognizing the cd drives but not showing them I'd try a windows repair might be the fastest way to a sure fix. Put your XP disc in and walk through the steps, when it finds your Windows installation press R to repair it. (should keep all your files / installed programs)
Feb 25, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 CD door closes quickly.
If an application is attempting to access the CD drive, the door will close. Put the CD in first and then launch the application.
Also possible a problem with the eject/load mechnism in the CD drive.
Oct 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
May 28, 2009 | Dell Dimension 8300 PC Desktop
I am Having problem restoring my dell 2400
Well you may have a bad mother board or IDE port to which the HDD is connected. If the CD is connected to the same IDE channel as the HDD, move it to IDE1 which is the second IDE channel. If it then recognizes your CD, IDE0 is bad and you need to replace your board. Let me know how things are connected inside the computer.
Apr 14, 2009 | Computers & Internet
Dell Dimension 5150 cd-rom stopped working
Open your tower and reseat all the cables that are running to the CD ROM (generally a flat white cable). Also reseat the other end of the cable to the motherboard too.
Ensure that CD Drive is enabled in BIOS (Press F2 as the system boots up to enter into BIOS) Please get back if you need any further help.
Jan 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
DVD/CD ROM problem (Dimension 5150)
you cleared the bios settings by removing the battery.
Go into the dell bios at startup F2
make sure it sees the cd rom drive
then save and exit
should fix the issue
Jan 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
