Question about Ricoh Aficio 180 Laser Printer
"Reset fusing unit"
Hi I asked yesterday about the fusing unit on my ricoh aficio 200. There is no button to press anywhere near the cord on the machine.
Am I looking in the wrong place? I checked near the cord...then the whole back of the machine...and the sides. I see nothing that looks right.
    An expert whose answer gotĀ voted for 100 times.
  • 86 Answers
Please open the front door and in the middle you will find a brown cover. Unscrew the screw of the cover and pull out the fusing unit.
Push it back carefully, close the front door and switch on.
If reset fusing unit is still there, probably the socket at the rear of the fusing unit is out of place. If it is Ok, then there is the plug mounted at the back in the machine which is out of place.
It will need to remove the power supply unit from the back, to be able to access this plug and adjust it.
Good luck.
Posted on Jan 13, 2009
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
I had a functional problem sc 546 with my copier Ricoh 2022
Hi mkpack,
The error code SC546 that you're getting with your Ricoh Aficio 2022is related to unstable fusing temperature. There are two possible causes for this issue. These are, the thermistor is already defective and/or the crusted toner on the fuser roller. To reset this error code (SC564) you might to follow these steps:
1. First, press the yellow clear all button.
2. Then, select 107.
3. Hold the red stop button until the machine switches to SP Mode.
4. Afterwards, press the copy SP or system SP button.
5. You have yo shut your machine off and then turn it back on.
If after doing these steps and still you're encountering the issue you might need to remove the fuser and clean it. Also, you miht need to replace the thermistors. It's the black aluminum roll in the fuser unit.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Ricoh Aficio 2022 Black and White Copier
I am looking for thresdhold when the Ricoh aficio sp c420dn printer sends out the toner low message. Is it 15%? I cant find this anywhere. There are other Ricoh models also.
Ricoh sense toner in the following methods:
Toner Near End
To detect the toner near-end, the machine uses:
Pixel count (memory chip on the AIO)
AIO rotation distance (memory chip on the AIO)
Toner End
To detect toner end the machine uses:
Output from the TM sensor (center)
After near-end, it is estimated that 200 pages (A4, 5% coverage) can be printed until toner
end occurs.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 01, 2011 | Ricoh Aficio BP20N Laser Printer
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
My ricoh aficio mp3010 keeps comming up with error sc 548 any body now wat to do. please help me
You need acces service progpam:
1. Press the clear modes key.
2. Enter 1-0-7.
3. Press the clear/stop key for more than 3 seconds untill the service program menu appears om the touch pamel display.
4. Enter in the service menu.
5. Turn OFF the power switch,unpluged cords,wait 10 sec,plugged cords then turn ON power switch.
Aug 02, 2009 | Ricoh Aficio 450 Copier
Problem replacing fusing unit for a Ricoh Aficio SP C411DN
Look in your owners manual for the set of reset keys you ppuch to reset the error in the machine. Can't tell you much other than it is a sequence like holding POWER button and 1 or 2 other keys for so many seconds. Have you tried to ask the question at their website?
Here is the location for the manual
Jul 15, 2009 | Office Equipment & Supplies
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Fusing Unit
If you will look where the power cord is plugged in, somewhere immediately close to there you will see a reset button or buttons similar to those you may find on electrical receptacles in the house. It is like a circuit breaker. Press it in to reset. It should be clearly marked as well.
Jan 08, 2009 | Ricoh Aficio 180 Laser Printer
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 180 Laser Printer Logo
473 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
