Question about Acer Aspire 3000 Notebook
4 keyboard keys aren't functioning
The keys of l,k and o aren't functoning. I have used a soft toothbrush to clean around the keys and don't want to remove the keys to clean under them. What can I do ? and are there any products I can purchase to clean under the keys
  • lavita2 Jan 10, 2009
    I used compressed air and a laptop keyboard brush to clean the keys and still they don't respond. Could the keyboard need to be changed? please give info. on what to do
    If the Acer Aspire 3000 keyboard needs to be replaced due to certain keys not responding, it is hard to replace and can a 'lay person' do it, or does it need to installed by a computer tech.
    Sergeant:
  • 367 Answers
Chances are there is a physical problem with the keyboard. Are the keys sticky or do they press normally and still not work? If the keys are sticky when you push them you can remove the keyboard and keys and try to clean the keys with rubbing alcohol. Chances are the keyboard is not defective and the link below will help you take care of that problem. If you need any further help let me know.
I am including a link to a new keyboard for your model Laptop. They are fairly reasonable condidering they are laptop keyboards.
Posted on Jan 09, 2009
  • Rob Houg
    Rob Houg Jan 19, 2009
    Should be easy to replace the keyboard, Possibly release tabs underneath some plastic covers that should just pop off. I am currently searching for your exact model but am having problems locating the instructions with pics.
  • Rob Houg
    The installation procedure is the reverse
    of the disasembly procedure? Ok so I was a bit of a smart ***, and you
    probably haven't disasembled the laptop yet.
    I've taken exactly one laptop apart, and after a year or so still
    haven't put it back together, so do what you will with my advice and
    whatever you do don't force anything.
    More than likely your laptop has screws you can see on its bottom, so
    take those out. Some screws will be of a different size than the others
    and you'll want to be able to remember exactly where each screw came
    from, so number each screw and draw a diagram of where they came from.
    #3 is the "Screen Hinge Cover Plate"
    You'll have to take a close look at the screen hinge cover plate to get
    it off because it's probably just snapped into place. Once you take off
    the screen hinge cover plate you'll see a few more screws that you'll
    need to take out, number and draw a diagram for.
    Once you have all the proper screws out, your laptop clamshell should
    open up. The keyboard is probably attached onto the bottom part of the
    clamshell with a few more screws and with a ribbon cable to your
    motherboard. Just slide the keyboard ribbon compression bar away from
    from the main fitting and remove the ribbon from the fitting. Now slide
    the new keyboard into place and do the reverse of these instructions.
How do i fix toshiba satellite C850D laptop some keys not working
1) open the buttons and clean underneath them by a toothbrush.
or
2) remove the keyboard (you can see how to remove it online or get back to me if you can't find it) and clean the wire belt gently, maybe something is stuck in there.
or
3) if the above didn't work and you don't want to spend money on a new keyboard, try using a keyboard app.
or
4) the best desperate solution (which i used to solve my problem) is to use SHARP KEY app, which enables you to switch a key to an alternative, less used button.
Mar 06, 2015 | Toshiba Satellite Computers & Internet
Why did my enter key suddenly no longer function as to enter, when pressed it brings up a toolbar instead of taking to the next line?
your keyboard utilizes keys F1-F10 as re-programmable function keys.to change your current pofile press the razer lycosa logo+functon key(f1-f10) or you can reset your keyboard to factory default settings by pressing the "Razer Logo" button for 15 seconds while the Razer Lycosa is connected to a powered on computer. NB: ALL CONFIGURATION SETTINGS WILL BE LOST WHEN YOU RESET THE RAZER LYCOSA
TO FACTORY DEFAULT SETTINGS. ALL CONFIGURATION SETTINGS WILL NEED TO BE
RE-ENTERED OR LOADED FROM THE CONTROL PANEL AFTER THE RAZER LYCOSA IS RESET.
Jul 21, 2013 | Razer Lycosa Gaming Keyboard
Keyboard typing wrong letters
Your keyboard is not "typing wrong letters", you have a stuck key. The key is shorting out and is stuck on the letter W. Usually caused by dirt/dust/spills on the keyboard jamming the key so it can't release. Things to try in order of difficulty:
>Vacuum cleaner with brush attachment, vac the keys.
>Paper towel moistened lightly rubbed on the 4 sides of the W key; use a knife blade to gently work down into the edges.
>Soft toothbrush, lightly dampened with water, work the bristles all
all around the edges of the W key. After that do step 2 with a dry
dry paper towel.
>Take the keyboard apart; usually several tiny screws on the rear/sides. CAREFULLY remove the top. You may have to turn the board over, lie on its face to do this. Do not knock the letters out of order or you will have a headache placing them back in proper order! Clear whatever it blocking the W and replace the cover.
If none of the above works the keyboard has failed, needs to be replaced.
Jun 08, 2013 | Samsung Computers & Internet
My functon keys are not working properly
Have you tried going into System Preferences/Keyboard, and see if there is a checkmark next to 'Use all F1, F2, etc. keys as standard function keys.'
May 25, 2012 | Apple MacBook Pro Notebook
How can i fix sticky keys on my laptop without taking it to an repair shop
Most keyboards have plastic, mechanical keyswitches underneath the keycaps, and you can probably pop off the keycaps pretty easily (use a small, flat tool and very gently lift up on end of it till you can get a grip on one end of a keycap with your fingers, after which, you can pretty easily lift and unsnap the keycaps from the keyswitches below and see if any foreign matters are present and clean 'em out.
To clean a keyboard, I recommend a used paint brush to dislodge hair and fiber in between keys, a damp (not wet) toothbrush to clean the surface of your keycaps, and a good ******** (don't use a vacuum unless you're willing to dig into your vacuum bag for tiny parts that may get accidentally sucked out!).
Outside of some odd-ball laptops models, most keyboards can be easily found on eBay and are pretty affordable ($10-$15), so I'd look for one on eBay before I start fixing mine - just in case.
Sep 11, 2011 | Computers & Internet
When playin my yamaha psrE313 i notice that sometimes when I hit the C note it plays at an intensity based on how i touch it, but it will suddenly jus play at max intensity. That is to say if i touch it...
Hi Mikey,
Being a keyboard player and owner of various different keyboards, I wonder if there is a button there that either activates/deactivates the 'touch' sensitivity of the keys. As you say it only happens on the "C" key, I can't narrow it down to anything specific other than something may be under the key itself. If you are mechanically inclined, you can remove the bottom and be gentle, take it apart and see if there is anything inside the keyboard to make it stick or is jumping across the contacts. I've been inside a few of those units and they aren't as daunting as they may seem. If you don't feel safe to do this, you may just bring it to your local music shop and they would do it for a charge.
Hope this gives you some relief
Joe
Sep 07, 2011 | Computers & Internet
I am trying to find a keyboard layout so I can take the keys off and clean them. Do you know where I can download a picture or instructions for doing this. I have a Dell Inspirion 1525 Laptop. Can you help...
You can view (or download) a service manual at Dell's site here. It shows how to remove the keyboard, which will make working on it much easier for you and will prevent possibly damaging the laptop with any cleaning material.
Neither the service manual or the setup guide on the site show a detailed key layout. What I do is take a picture or two with my cell phone camera so I can remember how things look before taking them apart. You can also lay the keyboard down on a scanner, if you have one, and make a picture of it that way.
It's not hard to take the keys off as they just snap on. But they really aren't designed to be removed, and the thin plastic snap tabs are fragile. Sometimes they don't snap back on securely once they come off. Work carefully and don't use excessive pressure in snapping the keys back in place.
If you're trying to clean the keyboard because of a spill, you may just be better off replacing it. New keyboards aren't expensive (around $20 to $30), and as you'll see in the service manual they are easy to change. This site even claims they have the keyboard for under $10.
Whatever you decide to do, good luck with the repair, and thanks for using Fixya!
May 14, 2011 | Dell Inspiron 1525 Notebook
I have toshiba tecra model, some keys on keypad are not functioning .. pls advise .. By Renuka
if u have fall something like water or juice then u have to dissasseble ur laptop keyboard and clean the carbon points of ur keyboard using Aciton with tishue but if this not work then u have to change ur keyboard
hopw this will fix ur keyboard
Jul 30, 2009 | Toshiba Tecra A9-S9021V Notebook
Watch needs cleaning.
Find a good jewelry cleaner where you can soak jewelry (rings, earings) and let only the band soak. Use a soft or medium toothbrush to finish with the band, then dip the toothbrush in the cleaner to clean the rest.
May 11, 2009 | Watches
Acer Aspire 3000 Notebook Logo
222 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
