Question about Panasonic PT-51SX30 51" Rear Projection Television
Dark picture The picture is very dark. I have the brightness all the way up and some scenes are still dark.
    President:
  • 3,130 Answers
This is a common problem with Panasonic projection TV sets. There are a few differant things that can cause this problem though. The first problem could be a bad cocus screen divider assembley. This is what takes and adjust your foucus as well as the indivitual screen controls for each color(red, blue, and green). Another problem could be a bad capacitor in the sweep power supply that is supplying the screen voltage or whats called the boast voltage to each picture tube board. The next thing it could be would be a bad coil or resistor in the picture tube filiment circuit also in the sweep power supply. Now I heed caution my friend as non of these repairs should be attempted unless you have the full knowledge of how these circuits work and have the proper test equipment as well as the proper documentaion to repair these beast. Please if in any doubt, call a trained tech to assist you in this repair. Good Luck
Posted on Jun 04, 2007
4 Suggested Answers
SOURCE:
techman
  • 3130 Answers
SOURCE: brightness
Yes there is, you can very carefully take off the back of front speaker grill and the wood cover behind this. There you will see several controls I think six total, three on the top and three right below it, you want to turn up whats called the three screen controls for the red blue and green but you will need a B & W picture on the TV so you can balance the greay scale. if you do not balance the grey scale the TV will not look good. if you do not think you can do this adjustment properly, please play it safe and call in a tech to do these adjustment for you. Good Luck
Posted on Mar 23, 2007
  • 4 Answers
SOURCE: picture fuzzy on dark scenes
hey all...just to let you know, I had noticed a post that said the individual prior to getting or ordering new parts, he took the tv apart from the back, and cleaned.
My husband spent the better part of the day, vacuuming out and blow drying on cool all the dust and such. after doing this the picture was worse, HOWEVER, we noticed the flashing was gone. SO, he took it apart again, and this time, very carefully took apart the compartment holding the color wheel. He took out the lens, cleaned it with a lens cleaner cloth. Took out the color wheel, very carefully cleaned the wheel, cleaned out the whole inside of that compartment, put it back together, and VOILA!!!!!!
BRAND NEW PICTURE EVEN BETTER THEN WHEN WE GOT IT.... no lies, no problems, it was extremely time consuming, but I ccan't describe the difference.....UNBELIEVEABLE and no spending a grand on a part.
Don't hold me responsible for any problems, but this just worked for us, and my tv is NO LONGER FLICKERING,, NO MORE LAVA LOOKING COLORS, NO SHADOWS.
JUST CRISP! WOO HOO, I DONT HAVE TO BUY A NEW TV... yet.
Posted on Feb 01, 2008
  • 126 Answers
SOURCE: Mitsubishi WD-62527. Dark picture.
That unit is a two mirror set. Meaning the light engine lens shines down onto a small mirror and that is reflected onto a large mirror and then onto the screen. Gravity being what it is dust and other contaminants cover the lower mirror. Moving the set would only aggrevate dust settling on it. To fix the problem the screen must be removed and the mirror cleaned. You won't believe the difference. It will be like watching a new tv.
Posted on May 28, 2009
Jvc 61g787aa picture too dark on night scenes
Did you try going into the menu and increasing the picture brightness?
Jan 30, 2014 | JVC Televison & Video
Voire 46" plasma tv- best color settings, to much white
The proper way to set flat screen tv's is opposite of old school CRT tv. First, find a movie with dark scenes and pause on a really dark part. Now set brightness only high enough to see some detail - no more. then go to a really bright scene and set contrast just high enough for good brightness. You may need to go back and forth a few times to get good setting.
Dec 21, 2013 | Toymax Viore 42 in. Plasma TV
The picture tends to get really dark during dark scenes. Can hardly see faces or details. Goes back to normal during brighter scenes.
the only thing you can do is adjust your brightness, contrast, sharpness controls. every station is different especially the sound is louder on some channels and lower on some.
Mar 05, 2010 | Hannspree (K206-10U1-005) Television
Brightness difficulty
I had the same problem and so went into the menu and selected brightness and increased the number, and my dark pictures were much better.
Jan 26, 2009 | Protron PLTV-4250 42 in. LCD Television
Picture getting dark
My jvc 27" tv was so dark I could hardly see any night scenes, even with the bright all the way on. If you push the sleep button, let go, then hold down the video and display (together), the service menu will come on. Scroll down to #7 (too dark) and adjust the brightness there. Works immediately. Good luck.
Nov 29, 2008 | JVC AV-27530 27" TV
Picture is too dark
How many years is your TV now? Usually TV has its life span, there comes a time that it happens. And need to look for a technicians, cause some of theme can still be repair by adjusting the brightness inside your TV.
Oct 19, 2008 | JVC AV-27530 27" TV
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Darkening tv picture
The Picture tubes(not bulbs) do and probably are weak. There replace should only be done by a trained service person. One reason would be the hI Voltage issues related to the crt's, as these tubes store alot of HI voltage even after its unplugged for a while, and another reason would be that these tube can very easy implode then explode and that wouldnt be a pretty sight. Third would be the alighnment involved after all three tubes are replace. There ba cross hatch generator and alot of time involved with the alighnment. Please seek a pro to assit you when your ready to spend at least 900 TO 1000 bucks. Good Luck
Jun 30, 2006 | Hitachi 53FDX20B 53" Rear Projection...
Panasonic PT-51SX30 51" Rear Projection Television Logo
94 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
