Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Water leaking from dishwasher
Have moved the dishwasher and as it was tipped forward, water pored from back of machine from the bottom as if a pipe had broken. Is this normal when bosch classixx dishwashers are moved??
  • gibsoneh150 Feb 21, 2009
    Water pumping out under dishwasher
Check the hose in the back to see if it split could be dry rotted
Posted on Jan 15, 2009
    Genius:
  • 1,605 Answers
Chek the drain at the button of the machine. you may have disconnected the drain pipe.
Posted on Jan 09, 2009
My Bosch Classixx (about 10 years old) dishwasher won't fill The problem has only started since I pulled it out and cleaned! The programme sounds are as normal but no water enters the machine. I detected...
Check you dont have a small inline filter inside the inlet water pipe. Either at the "tap" end or can be on the machine itself. They look like a small sieve. Remove it and clean with a toothbrush. Then put back.
Apr 05, 2017 | Bosch SHU9915UC Dishwasher
Not draining and check water light on
you have a blockage in drain pump consult manual for cleaning process when water drained away check water light will go out.
May 27, 2010 | Bosch 24 in. SGS43C12 Classixx...
I have a bosch sgs53c12 dishwasher and the water light keeps comming on after about 20 seconds into a programme. I have switched it off and on, reset it and checked the inlet hose where it connects to the...
Hello- Bosch installed an anti-flood device in bottom of unit. If water gets into this area ( from a leak, usually). To get water out, tip backwards, then forward. Use a couple of towels- water should come out. Common problem with these units. Let me know if this info helps- have more if needed.- Thanks- Ed
Mar 12, 2010 | Bosch 24 in. SGS43C12 Classixx...
My d1716 continues to run, but does not move forward in the cycle. I can even open the door and it continues running. If I didn't unplug it, the motor would likely burn out. Do I need a new dial? Thanks.
Hi
I would suggest that your flood switch has been activated. There is a float on the bottom plate or base plate of the machine. If there is a water leak, the float rises and triggers the flood switch.
Once the switch has been activated, the machine will go on a continous pump.
Disconnect the power and the hoses from the machine. Pull the machine out and lay it on its back.
If there has been a leak, you will notice water pouring out the back.
See if you can open the bottom plate, and reset the floater and flood switch. Sometimes you can access this by openning the front kick plate or front bottom plate.
Try the machine again. Leave the front bottom plate out and look into the bottom as the machine is working. If you have a water leak, this will happen again and you may be able to notice where the leak is from.
Be carful not to touch the live wiring while you are monitoring the machine.
Good luck
Ash
Nov 20, 2009 | Asko D1716 Built-in Dishwasher
Open the dishwaser while still filling now keeps going to error
After reading a few of the other Haier models troubles, I pulled the unit out and tip it at 45 degrees backwards for around minute. Water pored from the back of the unit, once cleaned water up reinstalled unit and all seems to be back in working order.
May 16, 2009 | Haier Dishwashers
Conia dishwasher CDW0302 error 4
empty dishwasher clean drain in bottom, close door, check that drain pipe not kinked, tip forward to 45 degree, check pipe again when putting back down, you may have to tip it forward a couple of time if it does not work the first time
Jan 09, 2009 | Dishwashers
Outlet pump running continuously and not responding 665 favorate
i tried to move the machine arround, lean it forward back ward or side to side it stops working and starts again, it feels like a water levels sensor or some thing
Dec 23, 2008 | AEG Dishwashers
No water coming into machine. Programme not running because the machine is still trying to fill. If I add water the machine does drain. Was cleaned with a good dishwasher cleaner only last week. Nothing to...
Turns out that the dishwasher had a leak in the bottom. No water could be seen leaking out because Bosch machines have a cut-off valve that means if a tray in the bottom of the machine fills up with water, the float valve doesn't allow anymore water into the machine. we worked this out after we tipped the machine slightly, water ran out, when we put it back down and started it the inlet valve worked until the bottom had filled with water again.
New machine for us! However, not a critism of Bosch. We use our machine at least two or three times a day and have done for the last 5 years.
Sep 09, 2008 | Dishwashers
FDW60 flashing 'eco' light error
I had this problem and discovered it was due to a leak. The float switch attached to the bottom panel was operating. Pull out the mains plug, tip the machine on it's side (water will escape so get a mop ready), remove the bottom panel, 3 screws front and back, disconnect the connector from the float switch. Tape the connecter up out of the way and stand your machine back up. Try running it now. If you have a leak somewhere then you will get a puddle under the machine. If no leak, then I would suspect the float switch itself.
Apr 12, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Jun 27, 2006 | Indesit 24 in. DE73 Evolution...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
291 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
