Question about Sherwood RD-6108 Receiver
Amp powers on, but no sound is produced
My receiver powers on, all displays are working properly, but no sound is produced. I have tried connecting several different aux inputs such as the CD, video 1, 2 and 3, and the tape input. None produced sounds. I opened the casing to check for loose connections and broken fuses, everything is is connected with no blown fuses. Thank you for your help. -Addison
  • gknepp Jan 05, 2008
    It worked fine for months.  Then today, I had no sound.  The display looks as it usually does, but when I play a cd or the fm radio the sound comes on for two seconds, then goes silent.  I tried all the solutions for this problem in the manual.
  • ceoarn Jan 09, 2008
    All speakers function as desired when operating CD player. TV operation fails to come through the speakers except through the Rt. Front speaker. I expect that I have something wrong in my settings but have no idea what is needed. The test tone button plays through all speakers very well. I have downloaded the manual and hope to learn more but will appreciate your assistance. Thanks. Arnold
  • 883 Answers
A failed volume control potentiometer? it's possible.
Posted on Jun 04, 2007
No sounds from my yamaha HTR6030 Display is OK. All function keys working.Relay clicks. But no sounds.
Try connecting different sources to different inputs or fm source if nathing produces sound I would recommend to have it check by a tecnitian
Aug 19, 2016 | Yamaha Audio Players & Recorders
No sound produced by Yamaha RX-A820 receiver.
sounds like amp has burned out, disassemble and check for blown fuses.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jan 30, 2016 | Yamaha Audio Players & Recorders
Pioneer Radio in 95 Ford F-150 doesnt produce sound
Maybe there is a separate amp with an open fuse.
Dec 19, 2013 | Pioneer Car Audio & Video
My subwoofer output is not working properly. I have a sunfire signature that worked all the time. Now the power on the Sunfire will not come. Research says no signal from receiver. I swithed the...
You can prove the sub pre-output works by running an RCA cable from it to the input of a tape deck, TV or any other device that accepts Line In and will either display it or play it. Test it on VERY LOW volume at the receiving device.
Different sub pre-out cable?
Feb 11, 2011 | Denon AVR-4800 Receiver
I have a 2000 Mercury Mystique. I am trying to
There is a good chance that your car has a factory amplified system, it may say premium on the speaker covers if it does. Check to see if you hooked up the bue and blue white wires in the adaptor harness. The blue wires in the adaptor harnesses are to turn on the factory amp.
Aug 16, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
No sound
Yup, try opening the case and locating any fuses you can find. IMPORTANT! Make sure unit is unplugged from power source.
Fuses are somewhat like light bulbs in that they can an do burn out. Use ohm meter to test if fuse is good.
The fuses are usually just like automotive fuses so you can try to find an amperage printed or stamped on the fuse. Replace with same.
GL!
Sep 22, 2008 | Denon AVR-1604 Receiver
No display
I too have mine for 1 year and all of sudden it powers up for stanby and sound is produced but no display?
May 15, 2008 | Denon AVR-2307Ci Receiver
RCA Pre-Out Making Producing a Mumming and a Popping Sound.
the speakers hook to speaker wires not to any thing else no power no negative poles do you have a remote shut off switch connected to amp this would be important to cut off amp
when cut off amp if you still here the humming this can be an indicator of low power being produced by alternator alternators produce 14 anything below 12 would mean replacement of alternator
if alternator fine then you need to find new ground for amp and make sure you have a good ground for sterio this can be checked with a test light
to check a ground all you do is hook gator clip to power then touch test light end to ground on radio end light comes on got a good ground (make sure not to touch any other sterio wires just the ground wire while connected to power to check grounds)
if pulsing in test light on the ground means you have a bad ground
just disconnect move to better ground
check the amp ground the same way as decribed above
May 09, 2008 | Pioneer DEH-P3900MP CD Player
Sherwood RD-6108 Receiver Logo
288 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
