Question about Brother HL-2040 Laser Printer
Printer would not run
Hi
My brother 2040 printer would not print. when I turn it on the motor runs then all three lights start blinking. Once I shook it form left to right a few times and it worked but no for long. Can you help me?
Thanks
St. Clair
  • soneil7 Jan 09, 2009
    Thanks but that did not help.
  • Anonymous May 18, 2009
    This didn't help me at all
Shut off printer then open front cover , press go and hold follow switch on until ready led off . release go button press go twice wait 3 sec then press go 5 times then restart printer.
Posted on May 19, 2009
    Genius:
  • 1,913 Answers
Open the front door thenremove ik cartridge then check there is not any paper jam.then restart the printer.
Posted on Jan 09, 2009
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Raf
Nov 13, 2009 | Brother HL-2040 Laser Printer
Canon S630 Printer. Yellow light blinks 7 times, green once.
7 Blinks says that your printhead has gone out. Just needs a new printhead, QY6-0034-000. around $40.00
Aug 08, 2009 | Brother HL-2040 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
May 05, 2008 | Brother HL-2040 Laser Printer
All error lights blinking and fan running but won't print...
Yes Mr. Guest and Mr SwT,
Replace the fuser assembly unit.
Definitely the fuser got problem. This can be confirm by pressing the Go button and only the Toner LED will light up.
What had happen was right after the power blackout the fuser has fused together both rollers (heating drum and rubber roller) where the paper pass through in between the rollers. Since there was a power blackout, the printer fan has stop functioning and the heat was unable to disperse out from the printer. Suggest to improve on design to disperse heat using aluminium cage in case of power blackout.
Who ever has a Brother HL-2040 should definitely use together with a UPS.
chekamal
Apr 27, 2008 | Brother HL-2040 Laser Printer
All four lights are blinking.
It depends on what error your machine has, but it has a critical error, all four lights, usally needs fuser, sometimes laser depends on what is indicated when one presses and holds the go button either way it needs to be workshoped to enable repairs to be performed.. link to lights explain on the 2040/2070
Table below is only service errors like coyote_k has. ie all four lights then press go to identify fault.
Dec 23, 2007 | Brother HL-2040 Laser Printer
PROBLEM BROTHER 2040 PRINTER
Have you replaced the drum and toner? It sounds as if the printer is saying it's time. The motor constantly running usually means it's trying to add toner to satisfy the toner sensor, but it's empty.
May 29, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
80 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
