Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Humming of the motor
4yr old unit that makes a humming sound almost all the time. What type of repair could be needed or should we get a new one?
  • 700 Answers
Sounds like all it needs s an adjustment or possibly a loose nut when they made the unit. i would open the back and see whats making the noise my self.
Posted on Jan 10, 2009
Pump makes humming noise impeller spins slowly
sounds as if pump has stuck start winding switch , try giving Motor not the pump a sharp knock with a rubber mallet when you 1st turn on , this might jar it loose if not a new motor might be needed , if motor was larger then say 2hp then id say get it fixed at a motor repair shop due to cost saving but smaller sizes it's not worth it most times
Nov 23, 2013 | Pentair 1.0 Hp Whisperflo Pump
After turning the unit off, there is a hum for a few minutes, no fan noise, just a hum, and then it turns itself off eventually. The unit is about three years old and is otherwise cooling the room.
From what you have described, it sounds like the fan motor may be seized. In which case, it should be replaced. Depending on the age of the unit, it may be better to replace it than repair it. As parts and labor to repair it, can be almost as much as purchasing a new unit. As the motor assembly alone, runs about $150.00 + Labor.
I hope this has helped you and thanks for choosing FixYa.
Aug 10, 2011 | Friedrich CP10C10 Wall/Window Air...
A/C unit doesn't start all the time, makes a loud humming sound
mcdevito75 here, Sounds like the bearing in the fan motor is going out on you, Thses bearings are a sealed unit from the factory, check out any A/C repair shop in your area for repair.
Jun 23, 2010 | Maytag M7Y12F2A Air Conditioner
Making a loud squeal or hum during
Sounds like a motor with bad bearings. In that unit it would be the water pump or condenser fan motor. If the sound is coming from inside the unit it is the water pump.
Nov 08, 2009 | U-Line SS95 Stainless Steel
Turn AC on and only get a hum, no Fan. Repair
It does not make sense they overlooked it. It does make sense the fan motor is bad.
A fan motor must have a new capacitor. I would ask for a labor adjustment on the original repair.
Oct 02, 2009 | Dometic Rooftop RV Air Conditioner
A.C . makes a buzzing noise...
If you can make repairs yourself a motor is only about $40 and a capacitor about $10. Either could be the problem. If you have to pay someone to do it buy a new one.
Jul 02, 2009 | Haier HWR12XCB Air conditioner
Note: CDC-625 unit won't open, no discs inside
Wait, wait!
I bought one of these units from a flea market for $5.00. It said the tray wouldn't open. I picked it up, and noticed the same thing you did. Humming motor, but the tray stayed put.
I opened it up to check things out, and all that was wrong was a (very) stretched out belt on the pulley that opened the tray. I replaced it with a rubber band and it has worked ever since. Once the rubber band wears out I'll replace it with a proper belt, but for now, it was a 2 minute fix that's lasted around 11 months so far. I really, really like this player, and plan to keep it working for a long time!
May 27, 2009 | Yamaha CDC-685 5-Disc CD Changer
Air conditioner is frozen on the inside
I would shut it off...most A/C's never need to defrost...but I'm not 100% sure about some of the newer models....In my 35 years experience.I have never seen a defrost on anything but a freezer/refrigerator....a humming noise indicates a motor is frozen up...usually a fan motor..in your case it will be the evaporator/condenser fan motor...(your type has a double shaft..that has a fan blade for the evaporator and then another shaft upon which the condenser fan blade is attached...if this goes out it will hum...and it will definitely ice over....and these window units are never supposed to ice over...except when air is not blowing over the evaporator ..or air is not blowing over the condenser. Yes it will continue especially if the fan motor is going bad...and yes keep power to it off..or the compressor can burn out and that IS THE AIR CONDITIONER...if you lose that you may as well buy a new one as the cost of repairs will be more than a new unit.....usually....If you are lucky you can take the cover off an spin the fan blade by hand and try to start it while the blade is spinning to see if it was just stuck...but it may not restart after it stops...if it doesn't you will need a new fan motor. Also next time include the Make and Model #. thanks and good luck...than you for rating my effort...the Fang.
Apr 08, 2009 | LG Electronic Window Air Conditioner
Dryer won't start
sounds like the start windings in the motor have failed you will need a new motor to repair this.
Jan 22, 2009 | Dryers
Candy Fridge freezer
How old is ur unit? Often the motor mount you need to check that rubber make sure its not broken (bushing)or the motor directly touch the rest of the panel below. Or else you need a new motor to eliminate that noise. Good luck Hope this help!
Aug 06, 2007 | KitchenAid KTRS22EM Top Freezer...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
67 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
