Question about Sony Cyber-Shot DSC-P31 Digital Camera
Power problem I cannot get the camera to switch on - no amount of new batteries makes a difference. Just before it stopped working completely, it had moments where it would come on and then stop after a few minutes. I have tried brand new camera batteries, normal rechargeable AA ones but nothing works.
  • 883 Answers
Is there a reset access hole?
Posted on Jun 04, 2007
SOURCE:
Canon Powershop A430 Digital Camera wont work with new batteries. I tried switching and used both alkaline and some regular ones but it keeps saying the batteries are low. How can I fix this?
If the camera has a lens that extends when you power-on, it may have failed to park completely when power went off, due to the weak battery.
Gently press on the front of the lens barrel to attempt to seat the lens.
Then (with a good battery) turn-on the camera.
If you are currently using the NiMH AA rechargeable batteries, I would suggest you try standard Alkaline AA batteries. They have a bit more voltage than the NiMH and it might make a difference in this case.
If that does not work, you should phone Canon Service and see if they have any suggestions.
I am sure they have encountered this problem before.
Hope this helps,
Feb 18, 2011 | Canon PowerShot A430 Digital Camera
My S9600 was left unused [batteries left in camera] for several months. Now it will work fine with the mains adaptor, but is completely dead when on battery power. Have tried new batteries [rechargeable...
Sounds like corrosion on the battery contacts. I have seen battery contacts with a thin, transparent coating that came from leaking rechargeable batteries- doesn't look like the usual green crud, but it stops electricity from getting through. Try giving the contacts a scrape- you will need a long thin screwdriver or something of the sort.
Dec 01, 2010 | Fuji Finepix S9600 Digital Camera
Camera will not turn on, even with new batteries
Sounds the first basic recommendation to try new batteries you already covered. Although I do have to suggest, did you use the manufacturer suggested batteries? Yes, it does make a difference. THey are programmed with the exact amount of energy your camera needs. The generic ones could be a bit above or below making all the difference.
Here you can contact them for a repair: http://www.teleplancamerarepair.com/
This repair includes a cleaning too.
Jul 16, 2010 | Samsung S850 Digital Camera
Lense stuck out - camera powers on only briefly then stops - hear one "bing". Tried removing battery - does nothing with cable power only.
1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Feb 08, 2010 | Kodak EasyShare M1033 Digital Camera
When turning camera on the shutter opens then shuts straight away and switches off
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 11, 2010 | Kodak EasyShare M863 Digital Camera
Camera switches on for a second and then swtches off btterey is fully charged
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
Canon A95 stopped working with lens open
ur lens belt is broken relace it or write to me
Jun 17, 2009 | Canon PowerShot A95 Digital Camera
Batteries
firmware update is a update through a usb cable to update camera software internally from manuf website-try a set of energizer lithium batts in camera-not rechargable but i get over 500 pics on sngle set-some cameras won't register accurate bat levels or work well with recharables
Aug 20, 2008 | Vivitar ViviCam 8400 Digital Camera
Canon PowerShot G6 Stopped Working
no, there is not an internal battery in canon g6 for operating it.
probably the battery does not touch the internal connectors of the camera.
May 10, 2008 | Canon PowerShot G6 Digital Camera
Dead Canon A75
A complete camera failure is usually caused by a power problem. Naturally, after checking the batteries, you should inspect the metal battery terminals inside the battery compartment. Also, many cameras (including the Canon A-series) have a memory card door with a safety interlock lever (power switch) that is engaged only when the door is completely closed. Finally, I have learned (from a Canon camera forum at Digital Camera Resource) that there is a small fuse soldered to an internal circuit board that sometimes fails for no apparent reason with several different "A" series Canon digital cameras. The fuse story, with photos for those brave enough to void their warranty and open up the camera, begins inside this thread, "Canon powershot A85 spare part needed!!!" at this web link: http://www.dcresource.com/forums/showthread.php?t=18151 You'll need to read a couple pages down to get the entire story. Good luck.
Jun 08, 2006 | Canon PowerShot A75 Digital Camera
Sony Cyber-Shot DSC-P31 Digital Camera Logo
59 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
