Question about Samsung DVD-R135
Will not initialize a new disk; often freezes up when trying.
Put in new disk and prompt asks if it should be initialized. select yes, and player either freezes or ejects the disc without doing anything. Resetting per the manual does not always reset, and unit has to be unplugged to reset. It did initialize disks when it was brand new but started above problem at about 10 months. Not heavily used.
    Problem Solver:
  • 11 Answers
Hello, I would suggest opening the unit & cleaning the lens with a cotton swab lightly soaked with rubbing alcohol. Especially if it has been used in an enviroment wich is dusty or the unit has been smoked around. Also, are you using the same type of discs, Some discs are better quality than others try using Imation they read in almost anything. Also if you do have to clean the lens you may want to lighty lubricate the rails the laser moves on using a drop or two of 3in1 oil per rail.
If it still will not work then I would say that the laser pickup is failling. Specificly the laser used for burning the disc, Since there are usually two lasers one for burning & one for playback.
Posted on Feb 17, 2008
Code to initialize ami rowe jukebox
For full initialization, in service mode, press 3 to enter init. sub menu, type 0 for full initialization. Press popular, then put switch in normal position and initialization will begin. You can still select and play discs while initialization is in progress, providing you select from cd's already finished. The machine will continue initialization after selections are finished playing.
Feb 02, 2013 | Wurlitzer Jukebox CD Player
I have a Gigaware 4GB flash drive. When I initially moved my files to the disk, I was prompted for a password to encrypt the drive. I didn't select one because I didn't want one or need one! I
when it asks for a password try just clicking in the password box and see if it accepts it
also you could download some software http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.htmlDr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
hope this helps you
Mar 18, 2012 | Electronics - Others
La Cie USB hard dirve its lighting intermittently red and yelow and the computer not recognized
Plug your usb drive into your computer. Then right click on my computer and select manage. Select disk management in the left pane. scroll down to look for your external drive in the bottom pane. You might need to initialize the disk by right clicking the gray area to the left of your disk on the bottom pane. If its already initialized you should be able to right click the disk just to the right of where you just clicked and select format, making sure to assign a drive letter and do a quick format of ntfs through the wizard that pops up. If the drive is labeled GPT protected you'll have to convert the disk to MBR by using the diskpart command. Go to start then run and type cmd and hit enter to bring up the command prompt.
  1. Type diskpart and hit enter
  2. Type list disk and hit enter and find your disk in the output
  3. Type select followed by your disk's number, for example "select disk 1"
  4. Type clean and hit enter
  5. Close the command prompt and now you should be able to initialize and format your disk.
Mar 04, 2011 | LaCie F.A. Porsche (301177) Hard Drive
Win 7 Ultimate will not recognize my LeCie big disk extreme back up drive. LaCie support was no help.
Mar 03, 2011 | LaCie Big Disk Extreme (300797U) 1000 GB...
No music adds
To reformat the NWZ-S545 Walkman follow these steps found on page 92 of the operation guide:
Formatting memory [Format]
You can format the built-in flash memory of the player.
Note:
  • If the memory is formatted, all data (songs, videos, photos, etc., including sample data installed at the factory) will be erased. Be sure to verify the data stored in memory prior to formatting, and export any important data to the hard disk of your computer.
  • Be sure not to initialize (format) the built-in flash memory of the player using Windows Explorer. If you have formatted with Windows Explorer, format again using the player.
  • This function is only available in the pause mode.
  1. From the [Home] menu, select [Settings] / [Common Settings] / [Format]. [All data including songs will be deleted. Proceed?] appears.
  2. Select [Yes]. [All data will be deleted. Proceed?] appears. To cancel the operation, select [No].
  3. Select [Yes]. When initialization finishes, [Memory formatted.] appears. To cancel the operation, select [No].
Mar 26, 2010 | Sony Network Walkman NWZ-S545 Digital...
Say's it needs to initialize and comes up with eisa.
The EISA partition is a partition that a computer manufacturer places on the disc to assist in recovery of that maker's files. It is not necessary to have this partition if you do not intend to perfrom a factory recovery. I will include a guide below to assist you in a deletion of that partition. To initialize a disc, it can be done ways, boot the computer and it will advise you the disc has not been initialized and will initiate a wizard to assist. I attach the hard drive to another computer using an EIDE/SATA to USB adapter, it will be recognized as an external drive but will not give it a drive letter because it is not initialized. You have to go to the control panel > administrator tools > computer management > disc management. Look in the right lower pane and it will show the drive with a grayed out box to the left, it may label the drive as drive 03 or 04 etc. Right click on the drive number and choose initiate. The computer will initiate the drive and give it a letter. It will also ask you if you want to initiate the drive as a bootable drive, choose yes. Below is the guide to delete that EISA partition so you can use the drive in any laptop you see fit.
EISA Partition Delete
1. Open a command prompt as administrator.
2. Run Diskpart application by typing Diskpart in the command prompt.
3. In the “Diskpart” prompt, enter rescan command and press Enter key to re-scan all partitions, volumes and drives available.
4. Then type in list disk and press Enter key to show all hard disk drive available.
5. Select the disk that contains the partition you want to remove. Normally, with just 1 hard disk, it will be disk 0. So the command will be:
select disk 0
Finish by Enter key.
6. Type list partition and press Enter key to show all available and created partition in the disk selected.
7. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
select partition x
where x is the number of the EISA based recovery partition to be removed and unlocked its space. Be careful with the number of this partition, as wrong number may get data wipes off.
8. Finally, type in delete partition override and press Enter key.
Once the partition has been deleted, exit from Diskpart, and now users can use the much familiar and much easier Disk Management tool in Windows (diskmgmt.msc) to manipulate the freed unallocated partition. Users can create a new volume (partition) with this space, or simply merge it to existing partition by extending the size of the existing partition.
Nov 19, 2009 | Toshiba MK8025GAS 80 GB ATA-100 Hard Drive
Boss BR 8...I insert the 100 mb disk, then asks to initialize..I enter 'yes' then it asks 'sure?' I enter yes then it says 'medium error' then ejects the disk..what's the problem?
If the disk had data put on with a PC you might try deleting all files and folders using the PC before formatting the disk in the BR8.
It is also possible that the media has gone bad.
A final try would be to degauss the disk and try to format on the BR8.
Sep 09, 2009 | Boss Micro BR Digital Recorder
Disk Initialize
If it's a DVD recorder, make sure you are using compatible DVD-R media. Check in the user's manual if it supports DVD+R or DVD-R.
May 05, 2008 | GoVideo Go Video DVD/VCR Combo
Disk boot failure
Not sure if your windows operation system is working. If so here are the instructions. Otherwise you can boot from cd (XP) and format the drive.
To access the disk management tool right click on My Computer and select Manage from the menu. There will appear a window with 3 categories in the left: System Tools, Storage and Services and applications. By selecting Storage, the menu will expand and from the dropped down list choose Disk Management, which is the purpose of this tutorial. In the right panel of the window there are shown the disks with partitions, as well as the CD-ROM / DVD-ROM drives.
Initialize new disks
New disks appear as Not Initialized. Before you can use a disk, you must first initialize it. If you start Disk Management after adding a disk, the Initialize Disk Wizard will appear, so you can initialize the disk.
So, right-click the disk you want to initialize, and then click Initialize Disk; in the Initialize Disk dialog box, select the disk(s) to initialize.
Dec 09, 2007 | Intel Server Board SE7505VB2 Motherboard
Sonic stage freezes when trying to delete files when trying to delete files using sonic stage the program frezes and will not allow me to delete any files from my walkman
If you haven't installed the latest version of SonicStage - v4.3, uninstall your version and install it from here: http://www.sonydigital-link.com/DNA/sonicstage/sstage_dl.asp?l=en&c=WM&sc=NWH&m=NW-A3000 If it still continues to lock up, I think that it's an issue with the database on the device. The easiest way to remedy this would be to initialise the disk and copy your music over again. To reinitialise the disk, go to the home menu, choose settings in the bottom left, go up once to "Initialize Disk" and select it, then select yes to proceed.
Mar 29, 2007 | Sony Network Walkman NW-A3000 MP3 Player
Samsung DVD-R135 Logo
117 people viewed this question
Jerry Greenberg
Jerry Greenberg
