Question about GE GSS25LGM Side by Side Refrigerator
Getting water in the tray in bottom
I keep getting water in the tray in the bottom of the unit to the point of overflow. Cannot figure where it is conning from? Could filter be blocked?
  • 24 Answers
Most refs have those bottom trays. They are intended to collect water from condensation inside the ref. It has a built-in heater underneath the tray to "heat up" the collected water to make it evaporate, so it should always stay dry. Some refs have a fan beside the tray and has the same purpose as the heater. I have a few suggestions to solve your problem: 1, Access the tray and see if it has a wire connected to it and if this wire is connected to the ref. If it is connected, it should be warm to touch, or you may hear (or feel) a fan running. If it's not connected, find the other end of the wire that goes into the ref, it is just near the tray usually towards the back of the ref. Connect the wire from the tray to this wire. This should solve your query. 2. If the heater or fan is broken, you may order them from any reputable repair shop that carries your ref brand. You may have them install the parts to your ref also. 3. If you are a DIY person, you may change the tray or fan yourself but I'm not sure if you could purchase parts in your area. Hope I helped solve your problem...
Posted on Jan 09, 2009
Why is my air con leaking out the front of it I want to get to the overflow pipe inside but dont know how to remove the front caseing other than the filter part
Check where the condensate pipe goes onto the ground first as sometime spiders or wasps will block the end of the pipe. It is unlikely that the pipe is blocked inside although as you have seen the water does flow out inside..
Feb 29, 2016 | Filter Heating & Cooling
Ice maker overfills the ice tray, ejecting large block of ice instead of individual cubes.
What is your model number? Sounds like you may need a new icemaker. Sometimes when the icemaker motor goes bad it causes the icemaker to keep filling even though it hasn't kicked out the ice in there. Also, are you sure there isn't 2 valves on the refrigerator?
Nov 15, 2015 | Refrigerators
Just recently, the ice maker stop dumping the ice cubes from the tray into the bin.
I believe the "tray" is supposed to get heated at end to let the ice release. Faulty "heater connection?" May need repairman diagnostic.
Jan 09, 2018 | Liebherr Refrigerators
My Panasonic Air Con (CS-C12GKH) is leaking water. This happens every few months and each time I have to get a technician to come. Is there a way to permanently resolve this problem?
The water is leaking due to a blocked drain (because of accumulation of mud). If you are able to clean it on your own, you don't have to call the technician. When you remove the houseing of the indoor unit, you can see the water collection tray at the bottom of the unit - thats what you have to clean.
Feb 14, 2011 | Panasonic Room Air Conditioner CWXC104HU
Central air unit/ Lux500 thermostat
There is usually an overflow tray which has a shutoff valve when the tray is about to overflow water into your house. It is not located outside on your unit but inside where ever the condenser unit is. IF that tray is full of water, your unit will not turn on until it is emptied. Then you need to find out why the tray isn't draining...do you have a blocked drain pipe?
Jun 21, 2009 | Jackson 25 in. TempStar HH70 Free-standing...
DeLonghi DC89TTC Series Coffee Maker does not work
Your unit is probably wet on inside by bottom heater. Take apart and dry inside of unit. A hair dryer works good for blowing all excess water out and helps dry. If unit is still in warranty go to http://www.delonghi.com Call number they will tell you if unit is still in warranty if so they will replace for shipping costs.
Jun 03, 2009 | DeLonghi DC89TTC Coffee Maker
Water leaking to bottom of freezer
ok you have a blocked freezer drain. The best thing to use to clear this is 'curtain wire (the plastic coated wire you use to hold up net curtains). Ok you need to find the drain hole in the "small tray on the back wall inside that fills and freezes and then the water is overflowing at this point to the bottom of freezer" you want to gentley feed the curtain wire down the hole untill the water drains down there. If you can't get the wire down you may need to turn the unit off to defrost as it could be frozen solid with ice. cheers
May 31, 2009 | GE Refrigerators
Drip tray full of water, don't know how to get it out to dump
How to remove drain pan on a kitchenAid side by side with water filter .
Nov 11, 2008 | KitchenAid Superba Architect KSCS25INSS...
GE GSS25LGM Side by Side Refrigerator Logo
98 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
