Question about Kenmore 22422 Top Load Washer
Agitator will not move unless you press down on it.
I have a kenmore series 80 washing machine. How do I remove the agitator?
  • Anonymous Mar 13, 2014
    agitator doesn't move unless I push down on it
  • 5,911 Answers
If the agitator is slipping, you may have worn out agitator dogs. Yes, there is such a thing. These are small plastic clips that act in the manner of a clutch for the agitator. The following link explains:
The link also explains how to remove the agitator. If you require addtional assistance, please let me know. I hope this helps you.
Posted on Jan 09, 2009
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Kenmore 80 Series washing machine agitator is not moving much
sounds like you motor coupling may have broken, part is about $20
Jan 17, 2010 | Washing Machines
Replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Jul 03, 2009 | Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore 80 series washing machine agitator will not rotate
you need to replace the agitator dogs, very simple. Go to and download the tutorial, thanks
Mar 01, 2009 | Kenmore Washing Machines
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
264 people viewed this question
Sal De
 Brian Main
Brian Main
