Question about Canon PC1061 Copier
MULTIPLE FEED PROBLEM
WHEN TRYING TO COPY MULTIPLE PAGES THE DOCUMENTS ARE STACKED ON TOP....AFTER A FEW HAVE COPIED THEY STOP OTHER TIMES THE FEEDER PICKS UP MULTIPLE PAGES INSTEAD OF ONE I NEED HELP PLEASE
  • 100 Answers
There is a little with pad that is called the seperation pad. You can see this under the pick up rollers. Clean this off with some alchohol. It may fix the problem. If not a new pad is needed.
Speration pad needs cleaned or replaced. Its a $10.00 part.
Posted on Jan 09, 2009
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
Paper does not feed from top of my hp 7210 printer and can not fax from top feeder. I can not use the top feeder to copy multiple documents. Only bottom feeder works. When I have to fax something, I have...
The rollers on the feeder can go bad and the best way to solve it is to get a new complete assembly. Check the website under your make and model for the assembly. YOu might also want to check for paper jam
Mar 19, 2011 | HP Officejet 7210 All-In-One InkJet...
Pages sticking together when transmitting
This is caused by the feed and separator rollers are dirty or worn out. The simplest thing to try is to clean the feed rollers. you will need a cleaning solution, isopropal alcohol works very well. Available at local drugstores. you can approach this one of two ways, you can open up the document feed section and manually clean the rollers or put a few drops of Alcohol in the center of a piece of paper let it soak in a little and pass it through the document feeder, the paper should have a streak on the last half of the page if it made contact with the rollers. For best results do this a couple of times, for better results do both the manual and the pass paper methods.
Hope this is of some assistance.
Ed
Apr 20, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Top feeder jammed
try opening the feed in section and cleaning the rollers with a cloth moistened with alcohol if you have it (primarily for it's quick drying). The rollers can become 'slippery' as they get dirty.
Mar 11, 2009 | Canon Office Equipment & Supplies
Want to scan to pdf a document larger than one auto-feed tray
I'm just thinking off the top of my head but there is an option in copying called 'job build' in special functions. This enables you to add many document sets into one print job. This may also work for scanning although i can't remember trying. Try it.
Feb 16, 2009 | Canon IMAGERUNNER 6570 Copier
Scan multiple page documents
On my scanner, I feed the documents on the ADF feeder (paper feeder) and when it finishes one scan, I tell it to continue. It will scan all you docs and put it in on file that you can send as one attachment.
Sep 26, 2008 | HP Photosmart C3180 All-In-One InkJet...
I have an hp laserjet 3050 fax machine. When I go to fax several documents at one time, the fax grabs the whole stack and sucks them through. How can I fix this problem?
The first step is to insure that the top cover on the Automatic Document Feeder is closing properly. If it is not, the pages may multiple feed. If that is fine, then there is a pad that separates one page from the next in the ADF assembly. It wears out over time and begins to let the pages multiple feed. The part is normally replaced with the feed roller in the ADF at the same time. These are usually changed by a technician. The part #'s are RM1-0890 for the pad and RM1-0885 for the roller, you should be able to order them online.
Hope this helps!
May 15, 2008 | HP Office Equipment & Supplies
Fax Not working
Copying Documents If you make copies of multiple documents at a time, the number of pages the fax can scan into memory varies depending on the scanning resolutions as follows: * STANDARD and FINE result in the same resolution when making copies
* If MEMORY FULL appears on the LCD when making copies, reduce the number of documents to be copied or reduce the amount of total copies.
  1. Lift up the document tray.
  2. Insert the top of the document, face up, into the ADF (1) until a beep is heard.
  3. Adjust the document guide to the width of the document.
  4. Press <Resolution> to select the resolution.
    You can select [STANDARD], [FINE] or [PHOTO].
  5. Press <Start/Copy>.
  6. Enter the number of copies (up to 99) using the numeric buttons.
    To make a correction to the number of copies, press <Clear> and re-enter the number.
  7. Press <Start/Copy>.
    To stop copying anytime, press <Stop>. If the document does not eject, press <Start/Copy> for a few seconds, then the fax will feed out the document.
  8. The new resolution will remain until it is changed.
Nov 05, 2007 | Canon FaxPhone B95 Plain Paper Inkjet
Canon PC1061 Copier Logo
137 people viewed this question
old marine
old marine
