Question about Epson Stylus Pro 7600 InkJet Printer
Printer is displaying message maintenance req 0040
ALSO MY INK SEEMS TO BE RUNNING OUT OF YELLOW
  • davebceltic5 Jan 26, 2009
    Same problem epson 7600 error code 0040. Can not even print a status sheet.
    Genius:
  • 1,913 Answers
Refix the ink cartridge after clean .it seems like your ink need replacing.
Posted on Jan 09, 2009
Maintenance req 0040 on my epson stylus pro 9600 printer
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Aug 09, 2011 | Epson Stylus Pro 9600 InkJet Printer
We have an EPSON STYLUS PRO 9600. We have received the msessage MAINTENANCE REQ 0040. Can you help us, please? Thank you very much.
The codes should be in the owners manual. Otherwise go to the web site in the support area. Type in the printer model then look for error codes support.
Mar 01, 2011 | Epson Stylus Pro 9800 InkJet Printer
Boa tarde, Referente Epson 7000 Pro, erro fatal SERVICE REQ 000000 101. Como entrar no meu para resetar o waste ink system? Att
When is printers depletable supplies like ink, print paper almost runout is likely for caution messages to be displayed. In this situation, the printer requires new ink cartridge replacement. Refer from the printer compartments to ascertain the model brands of the old ink to make possible acquiring from retail the most compartible or replacement.
Feb 09, 2011 | Epson Stylus Pro 7000 InkJet Printer
I've encountered an Incorrect Yellow message upon turning on the printer HP2820
The printer would only display messages of functions commonly as ink shortages. For example, color printers with encountering ink shortge would display a message. However, continuing to print would produce least impressive cooration where for multicolored characters tend to appear in yellow. Also, printers with ink malfunctions require inspection of cartridges, ribbons, and compartments for mal alllignments. Readjusting the ink compartments would request performing test print sheets as reallignment check. At which situation, a continued malfunction would be detected as diagnosable by computer popup messages. Refer to the printer user guide. Good luck
Jan 11, 2011 | HP Office Equipment & Supplies
Epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Please rate the answer........
May 07, 2010 | Epson Stylus Pro 7800 InkJet Printer
My printer prints well, but with a displayed problem
This indicates that the Pump motor operation count has reached its limit. The remedy is to Perform Maintenance Mode 2 [CLEAR COUNTERS / CLEANER]
Sep 21, 2009 | Epson Stylus Pro 7600 InkJet Printer
Service required error 0001002d
Feb 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
Unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Mar 13, 2008 | Brother MFC-620CN All-In-One InkJet...
Epson sp9600
aha and your printer is not functioning right now isnt it, or it is still operational, either way that error must be solve or you will never use your printer. this error means that your pump motor is near end about 5% of its life is left. here is the sure solution for your prob. turn off your printer then press the left, down arrow and enter simultaneously then power on the printer. inside initialize the sponge and cleaner then turn off and on your printer. note: you will have to replace your pump cap assy. if it is already poor in cleaning otherwise your printhead will suffer.
Sep 21, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 7600 InkJet Printer Logo
1,379 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
