Question about Linksys Wireless-G WRT54G Router
Lexmark X6690 will not connect to router
I have tried two routers (linksys and belkin) both bog standard, no password security. Each time I try to set up the Lexmark I get as far as the point where the lexmark is trying to obtain an IP address from the router. The laptop I have connected to the printer (in order to run the printer driver and setup programme) is also connected to the same router. I have also tried entering the SSID manually, which makes no difference. I have had the printer, modem and computer all on the same table, within a metre of each other. The only thing I can think of is that the router was also connected to two other laptops at the same time.
I am on the point of trying to return the printer to Curry's but I suspect they will not take it back since the problem seems to be with our set up.
any help greatly appreciated!
    Sergeant:
  • 290 Answers
IF you have DHCP turned on on your router check and see what range of IPs you are using and use one outside the range and try setting a static IP on the lexmark like 192.168.1.100 or whatever the scheme is
Posted on Jan 09, 2009
  • 124 Answers
Your computer has two router infos in it remove the one and use only one router and it will hopefully work for you just go to my computer and remove program of both routers then reinstall one you wish to use
    Master:
  • 505 Answers
Is the printer wireless if not can't be connect to router
Cannot locate password on my router model F5D8635--4vI
Reset the Belkin to default settings and reconfigure SSID and Security Key(password). User manual can be found here: http://www.belkin.com/support/dl/pm00781ea-usermanual_uk.pdf
Jan 23, 2013 | Belkin Computers & Internet
Have a linksys router trying to connect need default password or cisco password
By default, the router has a SSID ID of 'linksys', with *NO* security, and *NO* password. Configure the router to enable security, and to set the SSID and to set a password.
Sep 15, 2012 | Linksys E2500 Wireless Router - Ieee...
Having an issue getting my laptop connected to the internet. The wireless networks appear and it shows that i am connected to the linksys, however i get a dns server issue when i try to go online. It shows...
I see that your having issues with you wireless connection, you mentioned that it is an old model Router that has a B wireless signal and that you are connected to the Router but you get an Error about the DNS having issues, try checking your Routers Network Key, make sure that your Network Key in the Laptop and Router are the same.
- to get in your Belkin Router you must type in your Default Gateway on you browser ex. IE, Firefox 192.168.2.1 then press enter after typing your Belkin's Default Gateway you should get a window prompting you for a user name and password
your user name would be admin and the password leave it blank then press enter unless you have changed the user name and password setting of your Belkin.
- check under wireless and security to see your Network Key/Security Key and copy what you have in you router and use it on your laptops network security to be able to access internet from your Belkin Router.
Hope this helps.
Apr 02, 2011 | Linksys Computers & Internet
I have a lexmark X6690. I am trying to set it up wireless but can not find the 'pin number' could you tell me where to look? Steve D
The "pin" number is actually the Wireless security. It comes from the router. If you're using WEP encryption, it's a 10 or 26 hexidecimal code (0-9 A-F) that is not case sensitive. If you're using WPA, then it can be any 8-64 character password that is case sensitive. Whoever set up your routner will have the code, or if it's WEP you can usually read it by logging into the router. If it's WPA, you'll have to generate a new code...at least that's the case in Netgear and Linksys routers.
Carl
Feb 19, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Enable security
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 06, 2010 | Linksys Wireless-G WRT54G Router
How do I set security for my Linksys WRK54G 2.4GHZ
http://192.168.0.1
or
http://192.168.1.1
or
http://192.168.2.1
Feb 04, 2010 | Linksys Computers & Internet
I have forgotten my password and need to connect a new computer to my router-the router is a belking plus mimo and I have a linksys wireless g speed booster -what do I do to fix this? Many thanks
Reset the both routers in order to go to the factory default setting.
BELKIN (192.168.2.1) normally has no user name or password. So just hit enter.
Linksys (192.168.1.1)
User Name: admin
Pass Word: admin
You can always change the user name and password
Good Luck!
Sep 04, 2009 | Linksys WRT54SG Wireless-G Broadband...
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Connection to a Belkin usb
if you are using the belkin utility (look at your task bar, there should be an icon that looks like a tv screen), open it and you will prompted with a belkin screen. now go to the AP List tab and locate the wireless name of you linksys router and connect to it. make sure that your using the same wireless settings like the wireless security (if you have enabled it on your router) so as to make the connection successful. if you are not sure about your wireless settings, open a web browser to a hardwired computer and type http://192.168.1.1 (default ip address of your router). you will prompted with a log in screen, leave the username blank and type admin (default password) on the password. then you will be prompted with a linksys screen, go to the wireless tacb and check your wireless ssid/name and look for the wireless security sub tab to verify the wireless password that you are using.
hope this'll help you
ciao
Nov 07, 2008 | Linksys Wireless-G Broadband Router
Yeah hey...belkin wireless router password reset
What is the brand of the router your using? This information will be from the router that you have. Use a wired connection from the router,check your default gateway (ipconfig) and type that numbers in your address bar. You will be able to access your set-up page, look for wireless tab and look for wireless security. You will see there your WEP key.
Jun 26, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Linksys Wireless-G WRT54G Router Logo
27 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
