Question about GE 31GT740 31" TV
Now it squeals when turned on
Tv had not been on all night about 4 pm turned tv on ran for about 10 minutes and shut off by itself. when turning back on tv clicked 4 times then stopped and stayed off. this happened multiple times unplugged tv for about 30 minutes then plugged back in and now it squeals, without touching any buttons, no change when I hit buttons. what's next take it to the roof and drop it!!!
  • 934 Answers
That is a CTC203 chassis that is VERY difficult to estimate without seeing it... The "squeal" symptom you described indicates that the HOT (horizontal output transistor) has shorted. (Q14401 RCA p/n#242224 (2sd2578)). But I would not stop there... Check also: Q14101 RCA p/n#244223, R14107 p/n#244214 (43 Ohm 1/4 Watt) and really go over the underside of the board for poor solder connections. Tri State Module can rebuild that board to like new for $100.00 dollars plus shipping. and even if a shop locally did the teardown and re-assembly that's a lot cheaper than the cost of a new TV of comaprable value. Hope this helps! Bill
Posted on Jun 04, 2007
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Tv shuts off itself
If it does not have any sleep timers set then it is malfunctioning and needs to be replaced.
Aug 19, 2014 | RCA F32650 32" TV
Samsung 6003 turns off and on by itself
Hello
You have posted to wrong place.
Regards
Ajay
Dec 06, 2011 | Samsung LN Cell Phones
Samsung HL-S5086W Television. 3 yr old. Never serviced. Last evening the TV started turning off by itself. It would turn back on easily and run for a few minutes. I unplugged a new Wii game that was...
Dont worry, the problem is coincidental to you installing the Wii. You need a new lamp.
What you are seeing is the lamp ballast/power supply attempting to start and restart your lamp. The resistance of your lamp to it's power source has increased to the point that it is shutting down, but has not blown out yet. You can find these at justlamps.com
Good luck
Jan 04, 2010 | Samsung HL-S5086W 50" HDTV
Tv turns on by itself
Hey Bubba,
If your TV is turning on by itself at about the same time each day you may have a timer activated, turn it it off, the TV's micro might need too be reset. To reset unplug your TV from the a/c outlet for at least 5 minutes.
Jun 05, 2008 | RCA P52926 52" Rear Projection Television
TV turns itself off after a few seconds, no picture at all
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Nov 11, 2007 | Sylvania SST4322 32" TV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
GE 31GT740 31" TV Logo
87 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
