Crosley 24 in. CDU600 Built-in Dishwasher
Problem for Crosley 24 in. CDU600 Built-in Dishwasher
No spray
By ddorey on Jan 09, 2009
Suddenly my dishwasher will fill up with water but doesn't spray the dishes
Solution #1
posted on Jan 09, 2009
Somewhat Helpful)
Richie_asg1
Rank: Guru
Rating: 87%, 428 votes
This sounds like the circulating pump motor is either defective or the linkage is broken. If it makes no noise when it should be washing. then it probably requires a new pump motor.
It's normally located at the lower front right of the machine, but turn off and unplug before removing covers.
If you just get a motor sound - you may just need the linkage.
The problem is sometimes caused by broken glass inside the pump assembly - so use care when handling.
Was this helpful?
Yes
No
Popular Solutions for Crosley 24 in. CDU600 Built-in
Questions and Unsolved Problems for Crosley 24 in. CDU600 Built-in
Do you recommend Crosley 24 in. CDU600 Built-in Dishwasher?
Answer
Answer
the pass through dishwasher wont fill up and heat the water it just goes to dump cycle
Answer
Bosch Aquasensor Dishwasher SGS5302AU/12 not working. Not progressing in cycle. Seems to be stuck on... (More)
Answer
I have a Crosley CDU 600 V under counter dishwasher and it seems to be leaking from around a... (More)
Answer
Crosley CDU600 Diswhasher Glassware has been coming out with a white film, especially older glasses.... (More)
Answer
I checked the hose to the sink drain and it is okay. Checked the bottom of the washer and no foreign... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
