Question about Mitsubishi WS-55809 55" Rear Projection Television
When i turn the tv on the picture is curved and disfigured for 20 to 45 minutes until it clear out and work fine., however the problem is continuing to be there and the time is becoming longer.
  • 4,234 Answers
Since the set corrects itself, it suggests a connection problem rather than a component failure. If you can solder, try resoldring the pins on the convergence ICs and post the results here. Please note that there are potentially dangerous high voltages present inside the set even when unplugged.
Dan
Posted on Jan 09, 2009
When I first turn on my Technika tv I get sound but no picture. After hitting the top of the tv it comes on. After a further few minutes the picture freezes and eventually fades away. Further hitting of...
The dreaded loose connection syndrome, this could be easy or hard to trace, only solusion is checking circuit boards for bad connections , it may be also capacitors in power supply neading replaced, not a novice repair
pete
Nov 11, 2010 | Televison & Video
Picture goes out right after turning on, have to
My 3 year old Sharp LC-40C32U would start up fine but within a minute would go dark (audio continued fine). For a while I could turn the set off and on again and it would be fine, but over time this became less effective. My solution, which has worked for a week now, was to a) unplug the set's power cord; b) after 3 minutes plug it back in and turn the set on; c) on the remote hit MENU and slide over to SETUP (3 clicks to the right if the screen is dark) and one up to RESET; d) hit ENTER and follow the prompts. This puts the set in it's factory configuration so you will have to rescan for channels. Worked for me.
Sep 24, 2009 | Sharp AQUOS LC-40C32U 32 in. LCD TV
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
KV36XBR400 fragmented picture horizontal overlapping lines
this will continue to degrade, almost any failure that can be affected or temporarily cleared up by hitting the set is caused by bad solder joints.
A good shop should be able to find and fix the bad solder connections for probably a little under $100
if you bring it to them and pick it up.
Feb 10, 2009 | Sony KV-36XBR400 36" TV
Picture won't come in clear until TV "warms up" for 15 minutes or more
Change the capacitors first per the instructions in the link below. Symptoms could be anything from high-pitched hum to no picture at all. On these defective models, I would start at the caps and work back. It won't hurt to replace them anyway.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Aug 28, 2008 | Polaroid FLM-323B Television
Curved horizontal lines in picture
Its Sounds like Convergence Circuit,If you take the Back off and look on the right side you should see a Board with Big black Ics Mounted beside a Large Heatsink,Mark the wires where they go and Make sure the POWER is Off Pull the Board out and Inspect the Connections from the ICS,you find Circle Breaks,They need to Be resoldered and That should fix the Set....
Jul 20, 2007 | Samsung PCK5315RX TV
Toshiba 42wh36p problem
you tv problem intermittent the problem is in the color circuit, vertical circuit.have a tech check your tv for repairs.good luck.
May 18, 2007 | Toshiba 42H83 42" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
