Question about Linksys Wireless-G WET54G 802.11g/b (WET54GSUK) Wireless Bridge
Does not operate
Does not function lights out Linksys Serial MGB20GC01324 MAC 001D7E08BAE6 PN WRE54G ver. 3-US, what needs to be done for this item to work
  • 1 more comment
  • rogerio_walc Jan 12, 2009
    None of the lights comes on; since I have just inherited the task I know little of its origin other than being told there is no warranty.
  • Anonymous Feb 22, 2009
    THE LIGHT CANNOT COME ON
  • Sean Osborne
    Sean Osborne May 11, 2010
    Do any lights come on at all when you start the router? Power light, etc?
    Is this a brand-new router for you?
    Sergeant:
  • 366 Answers
Be sure you can browse internet using wired LAN
Connect to Router using LAN cable and configure it.
Enable Radio and set security protocol.compatible with your PC wlan card.
Posted on Jan 10, 2009
Serial number for epsxe3 emulator intallation
The ver # (not serial #) will be on the label either on the bottom or back of the unit. expressed as either v. or ver .
Here's a link to the manual.
Do a factory reset, then install like a new unit. http://downloads.linksys.com/downloads/userguide/1224638357428/epsx3_ppsx1_ug_0.pdf
Mar 13, 2014 | Linksys EPSX3 EtherFast 3-Port 10/100...
Chain oil pump does not work when pumped. Eager ****** MAC 100 series
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here:
This is a little complicated so I am going in small steps.
M & D Mower
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “18-600016-27”
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
See “General Assembly” print
Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31
Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it.
See “Powerhead Assembly” print
Item 07; pn 219989; oil pump assembly
Item 04; pn 217168; pump/bar pad connector (hose)
Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model.
Item 17; pn 110653; O-ring
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 06, 2010 | McCulloch Garden
Linksys WRE54G
after hooking the linksys router to the modem hit the reset button on modem. this will allow it to set it up in dhcp and recognize its mac address.
Dec 16, 2009 | 2wire 2700HG-B Router (2700HGB)
Linksys wre54G range extender - lights went out and despite unplugging, disconnecing, autoconfig. and reset button maneuvers, there are no lights and no function. What's going on??? Is it broken, burned...
have you recently changed the firmware in the unit. you may wish to go to the linksys website and download the correct firmware for the unit and reflashing it.
do a google search on "bricked" routers, i've repaired a couple and it's semi-complicated but it does work.
Sep 25, 2009 | Linksys : WRE54G Wireless Range Extender...
Serial number pinnacle VER 10 500-PCI PN:230100161 MADE IN CHINA
This is illegal. Please buy this product.
I gave this answer for your best. Because with an illegal key you will not be able to download updates & get support.
Additionally you make a crime.
Jul 09, 2009 | Pinnacle Studio 500-PCI version 10...
Linksys Wireless-G Range Expander WRE54G does not work
Yes you can call Linksys about it if it is under warranty. Warranty is 3 years. Most likely just a configuration problem. Just give Linksys a call and they should be able to get you up and running
Jul 27, 2008 | Computers & Internet
Limited or noconnectivity
make sure that WDS is enabled on your your router and your router knows the mac address of your WRE54G. I would try that approach first.
Jul 23, 2008 | Linksys Wireless-G Range Expander (WRE54G)
WAP54G as AP -- WRE54G no DHCP
I had the same problem. Went through tons of emails and finally twigged onto one that had the solution. Sorry that I do not have the link but I think I know the solution.
The problem is probably in the router. Computers on the network can ping 192.168.1.240 and you can even open the application when you enter the address into your browser, correct? You are only half done.
On your router make sure that the Wireless Distribution Service or WDS is enabled. This is extremely important. You will need to enter the mac address of your WRE54G into the field in your router's advanced settings under WDS. That will connect the two devices together. Just as the WRE54G needs to know the mac address of the router, the router needs to know the mac address of the WRE54G.
I have ver 3 and when the connection was made, both LEDs went blue and the Link Status on the in the browser changed from ------- to the mac address of the router.
Give that a try
Jun 16, 2008 | Linksys Wireless-G Range Expander (WRE54G)
Linksys Range Expander...
Initially, it is possible that the WRE54G has not been configured to talk with WiFi AP/Router downstairs and all that is needed is to configure/set it up.
Setup (to be done in the same room where your WiFi AP/Router is installed and preferably with your daughter's laptop which can already connect to your network when it is near):
1. Download the LinkSys WRE54G Setup Wizard from the LinkSys site;
2. Use a LAN cable connection to the WRE54G Ehternet port (located underneath a flip lid in front panel) to one of your daughter's laptop;
3. Power up the LinkSys Expander;
4. Press the Range Expander’s Auto Configuration button for about five seconds. Normally this should be sufficient for the Expander to auto-detect and auto-configure itself;
5. Power off;
6. Move the Expander to your intended place of installation;
7. Again using your daughter's laptop, expand/install the downloaded LinkSys Setup Wizard. Soon as the program is running, follow the on screen instructions. Please don't forget to Save before exiting.
8. Move your daughter's laptop to its intended location and try the system.
Should you still need a User's Guide, it is available here.
Another possibility that we cannot discount is that the WRE54G is also not reaching your router downstairs. Perhaps what can be done is installing it not a floor down from your daughter's but halfway between your daughter's floor and your office downstairs.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Nov 16, 2007 | Linksys Wireless-G Range Expander (WRE54G)
Linksys Wireless-G WET54G 802.11g/b (WET54GSUK) Wireless Bridge Logo
118 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
