SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
SOURCE: GE Spacemaker Oven shuts off after 3 min
Had one of these brought into shop. Customer complained it would run for 3 minutes (on high), then would shutdown and clock would reset. We noticed that there was no fan sound coming from it when we first ran it. Bingo! found magnatron cooling fan blade came off the motor shaft. After getting into it, found that there was no E-clip or any other fastener. The blade was glued on only. So we used a two part 5 minute epoxy glue and reattached, let glue cure and ran repeatedly to make sure no damage had occured to Magnatron or supporting components. All is well now! Hope this helps someone.
Jay
SOURCE: Daewoo WM1010CC convection/ microwave combo unit issues
Likely takes a torx wrench or some other special star tool to open it.
Could be a bad relay a bad mag tube or a bad timmer or a bad door switch. Needs to be trouble shooted. You have to get it open and check the fuses and test the voltage on the pri transformer first.
SOURCE: GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
SOURCE: Microwave turned on but nothing inside to cook, so now it's dead!
Put him up for adoption before he burns down your house.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
