Question about Apple iPhone 3G
I forgot my passcode to unlock my iphone what do i do?
  • 4 more comments
  • gfernandez Feb 10, 2009
    MY IPHONE IS LOCK AND I DON'T KNOW MY PASSWORD IS A NEW 3G!!!
  • Anonymous Feb 12, 2009
    i have the same problem
  • tiangsonmike
    tiangsonmike Oct 02, 2012
    my iphone locked because they attempt a wrong password to open it
  • Anonymous Apr 09, 2013
    The pro article helped me much: http://www.windowspasswordsrecovery.com/... Hope it helps more users!
  • Anonymous Mar 16, 2014
    Put code in phone still won't unlock
  • Anonymous Mar 18, 2014
    forgot passcode
  • 20 Answers
It depends on the severity and the settings you have given the iPhone and whether you have the computer that you synced your iPhone with... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
==If you have the computer you synced your iPhone with==
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It  can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
==If you don't have the computer you synced your iPhone with==
If you don't have the original computer the iPhone synced with, the only solution is to force your iPod Touch into recovery mode and then restore it. You will lost all the data on the iPod Touch, but after this method is done, everything will work. You can find the steps to solving this problem here:
http://support.apple.com/kb/HT1808?viewlocale=en_US
Posted on Feb 13, 2009
I found this iphone and it has a passcode and it say to hook it up to itunes but when i do it says thias iphone has a passcode try again? what do i do
Posted on Dec 02, 2010
There is a very easy and simple solution for this.
Simply put your phone in DFU mode (check youtube or google on how to do that) and when iTunes will show you that your phone needs to be restored and updated so you click OK. As easy as that, no passcodes or anything.
Posted on Oct 18, 2009
  • 6 Answers
Hi i have a i phone 3g ive forgot the passcode, when i huk it up onto i tunes, too restore it , it says it cannot let me do anything due to a passcode???? which is the best way to remove the passscode?
thanks
Posted on Feb 23, 2010
  • 12 Answers
If you cannot remember the passcode , you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup).Ifyou restore on a different computer that was never synced to theiPhoneor iPod touch, you will be able to unlock the device for use andremovethe passcode but your data will not be present. Refer to Updating and restoring iPhone and iPod touch softwarehttp://support.apple.com/kb/HT1212
Posted on Oct 08, 2009
  • lynn rimes Jun 28, 2013
    will you lose text messages, call history, and contacts?
I bought this iPhone off a friend for my daughter, it was jailbreak but some how my daughter has put a password on to lock and she's don't no the password, iv tried it so many times now the apple sign is staying on the screen it won't turn off. Wat can I do to solve the problem?
Posted on Feb 20, 2011
Iforgot my passcode to unlock my iphone 3g
Posted on Sep 26, 2010
Just connect your iPhone to your computer that you normally sync with, do a sync with iTunes, and it will reset the number of attempts you are allowed. So it gives you 10 more tries. If you still can't remember, just do a sync again.
Posted on Sep 05, 2010
Restore on a different computer that was never synced to the iPhone or iPod touch
Posted on Jul 18, 2010
Does anybody have the solution to this problem. I need some help too.
Posted on Jan 01, 2011
  • 3 Answers
If you forgot iPhone passcode, you will need to restore your phone via iTunes.
Firstly you have to put your phone into the restore mode.
Plug your iPhone into your PC or Mac with the USB cable
Press and hold the power button at the top and then slide to power off the iPhone
Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
Open up iTunes and click on the Summary tab
Click on Restore to restore your iPhone. This will reset all your iPhone's setting to the factory defaults, including the Passcode. You should then follow the steps above to activate the Passcode with a memorable number and un-lock it.
Forgot iPhone Passcode How to Unlock iPhone Passcode
Posted on Aug 06, 2014
My iphone have been disabbled. Its a 3gs and i was running on ipad baseband which i can not restore with itunes. When i connect to itunes, it tells me to unlock my phone before it can synchronize. It was working well before this code error came in.
I read on the internet that i should delete the folder keychain using diskaid which i did and now my phone remains in ''iPhone disabbled'' connet to itunes.
Please someone should help me.
Posted on Jul 18, 2011
  • honestivity4 Jul 18, 2011
    when i also try to restore with my 4.3.3 it give error 30194. Nothing seems to work except for me using my phone to recieve calls but don't have any access to my main phone. Please help me!!!!!!
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
How to recover whatsapp data from iPhone in easy way? The method to me is to use the tool-Tenorshare Whatsapp Recovery. This powerful tool can help us recover all data in safest way. See more as below. Tenorshare WhatsApp Recovery
Posted on May 09, 2016
5 Suggested Answers
  • 192 Answers
SOURCE: i forgot my apple iphone
Try the Restore procedure from iTunes If you have problems. But first try the recovery procedure.
1.
Disconnect your iPhone cable but leave connected the other USB end to the computer.
2.
Turn off your iPhone holding the Sleep/Wake button. The red slider bar appears. Slide the bar and wait until the iPhone turns off. Or you could hold the Sleep/Wake and Home buttons at the same time until the iPhone turns off.
3.
While pressing and holding the Home button connect the USB cable to your iPhone. It should power on. Hold the Home button until you see the "Connect to iTunes" message. Open iTunes if necessary. You should see the "iTunes detected an iPhone in recovery mode..." alert screen.
Choose " Restore"
Posted on Feb 21, 2011
SOURCE: i forgot my passcode and now my iphone is disabled.....
how do i find out what my passcode is
Posted on Sep 11, 2009
  • 945 Answers
SOURCE: I forgot the 4 digit passcode for my iphone. Can
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
Posted on Nov 12, 2009
SOURCE: I forgot my iPhone Passcode.
PLEASE CANANYBODY HELPPPPP MEEEEE!!!
Posted on Jan 27, 2011
I forgot my passcode on my iPhone. Is there another way to unlock my phone?
Well, this is only possible if you have a backup without the passcode. Do have a backup?
Jun 09, 2015 | Apple iPhone 3G
How to remove forgot passcode
Follow the steps on this Apple page:
http://support.apple.com/kb/HT1212?viewlocale=en_US&locale=en_US
Sep 19, 2014 | Apple iPhone 3G 8GB - Black - Unlocked...
I forgot my iphones password`
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. You can also try plugging it into iTunes and it may be able to reset itself. iOS Forgotten passcode or device disabled after entering wrong passcode
Dec 14, 2013 | Apple iPhone Cell Phones
How to open my iphone if i forgot the passcode.?
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. You can try plugging it into iTunes to see if it reboots itself
May 07, 2013 | Apple Iphone A1303 16gb
I forgot my pattern to unlock my Samsung 1827 can my phone be unlocked? And how do I unlock it
Didn't catch what passcode have you lost on earth. You mean the iPhone lock password? If so, go to this page - forgot iPhone passcode to get the answer. Good luck.
Apr 18, 2013 | Cell Phones
Its disable and i forgot password
Hello , I allso forgot my iphone passcode and i unlocked it using www.unlock-iphone.org and the good part is that now i can use my iphone on any network worldwide , i use tmobile in usa now.
Dec 13, 2009 | Apple iPhone (16 GB) Smartphone
How do i reset a iphone if i forgot the password i put on it
Hi , I allso forgot my iphone passcode and i unlocked it using www.unlock-iphone.org and the good part is that now i can use my iphone on any network worldwide , i use tmobile in usa now.
Nov 14, 2009 | Apple Car Charger For At&t Iphone 3g 8gb...
Forgot my passcode
Bad News... you may have to Restore from iTunes. Here is some info from the users manual:
Passcode Lock By default, iPhone doesn’t require you to enter a passcode to unlock it. Set a passcode: Choose General > Passcode Lock and enter a 4-digit passcode, then enter the passcode again to verify it. iPhone then requires you to enter the passcode to unlock it or to display the passcode lock settings.
Turn passcode lock off: Choose General > Passcode Lock, enter your passcode, and tap Turn Passcode Off, then enter your passcode again. Change the passcode: Choose General > Passcode Lock, enter your passcode, and tap Change Passcode. Enter your passcode again, then enter and reenter your new passcode.
If you forget your passcode, you must restore the iPhone software. See “Updating and Restoring iPhone Software” on page 204.
Set how long before your passcode is required: Choose General > Passcode Lock and enter your passcode. Tap Require Passcode, then select how long iPhone can be idle before you need to enter a passcode to unlock it.
Nov 10, 2009 | Apple iPhone 3G
Forgot passcode unlock on iphone 2g
f u c k t h i s w e b s i t e
Sep 19, 2009 | Apple iPod touch
Apple iPhone 3G Logo
106,457 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
