SCSI board BJW 9000
Would you have a parts manual or know the part numbers for the SCSI interface board and cable on a BJW9000?
Would you have scsi cable for IR400 scanner board (length approximate 7 meters.
Posted on Nov 29, 2009
How do I connect a UP-D50 printer with a Sony Vaio?
Use a usb cable or SCSI to usb cable from either a Sony Store or ebay.
Youy will need apropriate drivers for your OS.
Key Features
• Superb Print Quality
• High Speed Printing, A5 Size
• Approximately 300 dpi Resolution
• Standard SCSI Interface, Compatible with
95/98/2000, Windows NT
4.0 and
• USB Compatible
with Optional SCSI to USB
Converter Cable
• Compact Size
Nov 14, 2014 | Sony VAIO Computers & Internet
What leads to connect scanjet 5470c scanner
First, a power adapter is required to connect your scanner. the power adapter must be supplied with the scanner. If your scanjet 5470c scanner is having USB interface or connectivity, then you need USB cable and if it is SCSI interface, then you need SCSi cable to connect to your PC. The cables are usually be supplied with the scanner. If lost, you may have purchase teh same. For further assistance, please visit the following link:
Hope the above information is helpful.
Jun 25, 2012 | HP Office Equipment & Supplies
Have been looking for a BJ-W9000 user manual for several days now and STILL cant get any help!!
I have the bjw 9000 manuel on my desk top
email me at and i will send you a copy
Oct 16, 2010 | Canon BJ-W9000 Copier
What does SCSI mean?
SCSI- Small Computer System Interface
It is a set of standards for physically connecting and transferring data between computers and peripheral devices.
May 29, 2010 | Microsoft Windows XP Professional
Is Termination Necessary?
Usually, SCSI devices come with the termination built into the device. Older devices actually had two or three terminating resistor packs plugged into the card or drive circuit board. More modern ones have DIP switches to turn the termination on or off.
Essentially, on a SCSI daisy chain ribbon cable with multiple connectors, only the first and last physical device needs to be terminated. Usually SCSI devices come from the factory already terminated. If you have only one device to connect check and see if there is a DIP switch to change. I would go ahead and connect it. If it works, it's probably already set properly.
That said, I have worked with daisy chains of SCSI devices where a particular device would only work if it were terminated even if it was in the middle of the chain. s
Jul 10, 2009 | Adaptec Ultra160 Scsi 29160N (1835200)...
Canon BJ - W9000 Error code: B800A
The BJW 9000 manuel is available as a free download I have downloaded it my self but dont have it at home why not do the same
Tony (withtrader)
best of luck
Feb 10, 2009 | Canon BJ-W9000 Copier
Kodak DS3500 scanner
Are you using a Kofax SCSI card or an normal SCSI controller like Adaptec?
By using a normal SCSI controller, is there an ASPI driver problem after a WIN XP update? After an update check the ASPI dlls in \sytem32. They should be version 4.71 or higher.
Check the SCSI connector pins and the terminator.
If available change the cable.
Scanner check:
Is the green lamp (Ready) on or is the red lamp (Error) on?
- green lamp on:
the internal self test is ok, but the internal SCSI interface may possibly faulty.
- red lamp on:
the internal selftest detect an error.
It's possible that the DC/DC power board, the CPU board or the power supply inside the scanner is defective.
After reassembling the front side camera you will see at the bottom a PCA board with some LEDs whitch indicate by red light the different voltages when power is on. You find the different voltages printed at the PCA close to the LEDs.
In case on or more LEDs don't shine the according DC/DC transformer on the PCA is defective.
Futher you see LEDs at the camera PCAs. They should be on too.
In case the CPU board has an defect you must have an special Kodak activation tool to unlock an new or used CPU board after exchange.
Jul 12, 2008 | Kodak Digital Science 3520DP Path-Through...
My Storegtek L80 can't recognize all of its tape drives
That thing required a SCSI terminator pack doesn't it.
If so, is it working properly.
I've had those things go out on me before leaving me to pull my hair out many times.
Jun 14, 2008 | Storagetek L80 DLT Tape Drive
Computer Programming Interface Cable for TM-271A Connections: Computer: DB9 F Serial Radio: RJ45 Microphone
perhaps this will help. I ran across it by accident
good luck
Dec 17, 2007 | Televison & Video
47 people viewed this question
