Question about Xerox CopyCentre C20 Black and White Copier
Need to have the serial number installed in machine.
We need to put our c20 under agreement with xerox. They require that the printed status page include the serial number which was never entered into the c20. How can we enter it?
    President:
  • 2,072 Answers
To access the serial number from the Control Panel:
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
    Need to have the serial number installed in machin - m20-cntl-pnl-status.jpg
  2. Press the [Up] or [Down] arrow button until 'System Admin Tools' is selected, and then press the [Enter] button.
  3. If the System Admin Tools has been passcode protected, 'Enter Passcode' will be displayed. Enter the passcode, and then press the [Enter] button. If the passcode is unknown, or has been forgotten, contact your System Administrator.
    If the System Admin Tools has not been passcode protected, 'Passcode Protect' will be displayed. Continue with step 4.
    NOTE: If the Enter button is pressed, 'Passcode Protect (No)' will be displayed. Press the Menu / Exit button to return to the previous screen, and then continue with step 4.
  4. Press the [Left] or [Right] arrow button until 'Maintenance' is displayed, and then press the [Enter] button.
  5. Press the [Left] or [Right] arrow button until 'Serial Number' is displayed, and then press the [Enter] button. The serial number will be displayed.
  6. If ther serial number is not diosplayed, enter it via the keypad.
Posted on Jan 09, 2009
  • Rick Kasper Jan 10, 2009
    if its a C20 that is exactly how you do it, that is directly from the manual and hoq i have done it hundreds of times,
Epson TM T88iii printer not printing
Since you are using the USB-to-serial converter, you need to select the serial interface in the printer driver installation.
  1. Uninstall the driver in Control Panel > Add or remove programs
  2. Restart the computer
  3. Install the printer driver again, this time select serial in the interface list
  4. Set the properties for the serial port to 9600 for the data rate
  5. Print a test page!
Sep 07, 2017 | Epson TM-T88III Thermal Printer
My c-20 copier will not print from glass. prints blank pages. will only print the ones placed on the feeder.
I know this silly, but you put the originals on the opposite end of the glass. I don't mean to insult anyone, but I don't know your experience with this machine.
The fact that it copies thru the feeder, tells me the copier is ok. The doc feeder uses the same optics.
hope this helps
Feb 07, 2011 | Xerox CopyCentre C20 Black and White...
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
CopyCentre C20 Black line showing up on the left side of the page
Hello sir; When you make copy is through by ADF? make another copy leave on the glass, compare both, is that same with the line then you have to replace drum blade, if first one with the line and second one without the line, then you need to clean a narrow strip glass on left hand side of the plateform.
Jun 05, 2009 | Xerox CopyCentre C20 Black and White...
XEROX C20 - Leaves a blank stripe down the side of the copy
Yeah the c20 is not sturdy at all. But that aside. Some things to do.
1, Unplug the machine, remove the back cover and on the right side you will see the main board.On the top portion of the board you will see a white ribbon cable. Unplug it and look at the silver contacts on the very end of that cable. Then reseat that cable. That may be the problem. More than likely though you have either a dirty mirror in the scanner. Which would require removing and cleaning the scanner thoroughly.
The laser may also need cleaning. The toner cartridges for that machine leave a lot to be desired also. When you get a bad copy remove the toner, shake it from side to side and see if that fixes the problem temporarily. The blades that put the proper amount of ink on the toner roll fail often.
The scanner failing would be my first thought.
Also go to Xerox.com, select support and drivers, then enter C20 in the search box. Then go to drivers and downloads and install the newest firmware for the machine. You may have a machine software issue.
I have worked on that machine since day one of its existence, I never did care for it. It is a cheap machine made by Sharp corporation for Xerox. It really isn't a Xerox product, they just stuck their sticker on it.
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
Xerox M15 Prints dark only on copies
If your on maintenance tell them you want a replacement. If you have a maintenance agreement you are entitled to an identical replacement. Write a letter, with the serial number, peoblem and tellt them you want to exercise your TSG agreement. Total Satisfaction Agreement.
Not fixing it is rediculas.
Jan 23, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox c20 doesn't print. the paper runs through & comes out blan
hello sir; you said this one is brand new, did you follow the installation instruction, no matter what, just di it again,
1, press "menu" ,
2, press up/down arrow keys until"new drum" display
3, press "mode/enter"
4, when you see"new drum unit?" press "1" to select "yes"
5, turn power off and on .
Dec 28, 2008 | Xerox CopyCentre C20 Black and White...
XEROX workcenter M20i prints codes at bottom of page
someone has gone into diagnostics and enabled Status Print Engine
Fix
1. press menu/exit key
2. enter # 1931 in that order
3. engine test(diagnostic) should be displayed
4. use arrow keys to scroll to, then select engine test(status print)
5. press enter
6. press the "2" key on numeric keypad to disable (status print)
7. machine will revert to Ready to Copy
8. power off and then back on the M20
9. Your done.
May 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Not printing full A3
Make sure the machine and the driver are set for A3 . Most likely the paper tray, or setting in the menu are not correct.
Or the driver paper size is not correct.
Jan 31, 2008 | Xerox DocuPrint C20 InkJet Printer
Xerox CopyCentre C20 Black and White Copier Logo
145 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
