Question about Logitech Harmony 550 Remote Control
Volume control Cable remote will not control the volume on tv I need to use 2 remotes
    Novelist:
  • 101 Answers
Try this:
1. Login to your Harmony Remote Account.
2. Click on the Settings button next the Watch TV Activity.
3. Choose Review the settings for this Activity.
4. When the software asks what device are you using to control volume, please choose the TV.
5. Continue through the setup until you are brought back to the Home Screen.
6. Click on the Update remote button and follow the on screen steps.
7. Once the update is completed, please test the Watch TV Activity.
Posted on Jan 21, 2010
Philips 19PS50S122 TV does not respond to remote control
Please check your batteries in the tv remote as they appear to be weak or dead. You will need to find the cable remote's paper guide in order to properly program the cable remote so it can change channels, volume, and power functions on the tv set.
Good Luck!
Rich Lilja
Jan 05, 2014 | Televison & Video
Have 2 tv's & both remotes have the same problems: 1)tv power button, 2)mute & 3)volume buttons don't work. I have: 1) changed remote batteries 2) booted the system 3) followed instructionsin owners manual...
Go back to your owners manual, as there are usually more than one code number for your system. Go through the procedure step by step and it should work providing you have the correct number for your TV. Remember if you are using your cable remote to control your TV, it's the cable manual you should use. Hope this helps.
Nov 02, 2013 | Televison & Video
Reprogramming my cable remote to adjust the cable box volume (and NOT my TV volume)
Look at front of cable box and see if vol controls also on it
Mar 13, 2012 | Televison & Video
Volume control does not work using the TV's remote, the cable remote or the actual volume control button on the front of the set - the volume that comes out of the TV's speakers is constant - about 33% of...
SO YOU JUST GOT A NEW TV ...BUT...THE VOLUME CONTROL IS NOT WORKING FROM YOUR CABLE BOX.
EASY! BRING UP THE IMAGE OF YOUR REMOTE FOR
YOUR CABLE (MORE THAN LIKELY, IT'S A UNIVERSAL).
CLICK ON THE REMOTE FOR INSTRUCTIONS FOR VOLUME LOCK.
IF IT'S A UNIVERSAL REMOTE, CLICK SETUP (TWO BLINKING LIGHTS) TYPE 993, AND HIT CABLE BUTTON.
VOILA! YOU CAN NOW CONTROL VOLUME FROM YOUR CABLE REMOTE!
Jul 03, 2010 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Time warner cable, LG TV. volume control
if they are the only buttons that do not work i would say the pcb needs to be cleaned
Jan 17, 2010 | LG Electronics/zenith 6710t00008 Remote...
Volume control on Insignia remote doesn't work.. Have to use cable box remote to control volume.
Your remote control may be faulty. If you can control the volume from the cable box and from the buttons on the TV - then I'm pretty convinced the remote control needs replacing.
Jan 01, 2010 | Insignia 26 in. LCD Flat-Panel HDTV
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Volume controls dont work when using remote
I would start by trying other codes on the universal remote. Sometimes codes will only work part of the remote such as the numbers or channels but not volume. Your motorola cable remote sounds like it may only need a good cleaning. sometimes when you take remotes apart it will look like somthing got spilt in it. I would start there first.
Mar 17, 2008 | Sanyo DS27910 27" TV
Universal cable company remote control codes
brighthouse remote code for panasonic amolifier to adjust volume
Mar 12, 2008 | Televison & Video
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
Logitech Harmony 550 Remote Control Logo
105 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
