Gateway GT1040 will not start
I have a Gateway GT1040 which will not turn on. The power supply was tested by jumping a green and black wire which brought the fan to life. The machine was unplugged and the power button pushed for five seconds. The memory and cards were all reseated. All cabling/wiring has been checked for proper connection. Still, no LED light or power when pushing the start button. The kids tell me the machine was working fine and they noticed this yesterday when trying to boot up. Is there a way to test the Start button? Any ideas would be greatly appreciated. Thanks
  • dugans15 Jan 09, 2009
    My mistake, Model GT4010
  • 158 Answers
Try shorting the power pins on the Motherborad. (establish contact manual. use screw drivers such that they touch both the pins). The power pins are the one the Start button are connected to. Remove this connection alone. If this powers up the system, you would have to get the Button replaced. Else there's something wrong with the motherboard. Kindly get back for any clarifcation.
Posted on Jan 09, 2009
How do jump start a psu?
standard atx psu. green wire to ground (black wire). some require a dummy load on the 5 v rail to stay on(resistor across red to black) a 10 watt 10 to 50 ohm will do nicely
May 30, 2014 | Computers & Internet
Replaced smoked RaidmaxKY-520ATX power supply. Replacement power supply does not turn on. Which wires are remote power up from mother board ?
You can actually test the power supply before connecting it to the motherboard. Take a look at the power supply pinout by CLICKING HERE. Jump pin 14 with 13, 15, 16, or 17 to turn it on. You will have to get a manual for your motherboard to see how the front panel connector is configured with your case power switch. If you have that manual you can jump the 2 connector pins for the power switch to test the p/s from the motherboard.
Jun 03, 2011 | RaidMax (KY-520ATX) 420-Watt Power Supply
Start up light flashes once and it won't power on
Most probable cause is the power supply. Look at the back of the computer, check the voltage settings located near the power cord. This will be the small red tab indicating two different settings, If your in the US it should be set to 115. Also, the power supply should run the internal fan when it is turned on.
To test the power supply try this:
Open your computer case and locate the gray box that is the power supply unit. Trace the wires from the power supply to the boards and devices and disconnect all the cables by unplugging them.
Find the big connector plugged on the the motherboard, make sure it is disconnected and short the two pins: (GREEN & BLACK) Short green pin (14) to GND (any black) to switch power supply ON, disconnect green from GND to switch OFF.
This will switch the power supply, you should hear or see the fan in the power supply spin. If you do not see the fan spinning, and your sure you have shorted the correct wires, you have a faulty power supply. If you see the fan spinning, you can now test the voltage coming out of the power supply.
Place a volt meter on the following colors to test voltage:
The color code for the wires is: Red = +5V, Black = Ground (0V), White = -5V, Yellow = +12V, Blue = -12V, Orange = +3.3V, Purple = +5V Standby (not used), Gray = power is on (output), and Green = Turn DC on (input).
Feb 12, 2011 | HP Pavilion a6110n PC Desktop
How to power up a compaq 243890-001 power supply without the the motherboard? Its not green to ground
Remove Power Supply
1 . Shut down your computer and unplug the power cord and all cables connected to the system.
2 . Open the computer case and disconnect all power connectors from the motherboard, drives, cards and fans.
3 . Remove the four screws that secure the power supply to the case. These screws are located on the back of the computer case, at each corner of the power supply.
Wire and Start Power Supply
1 . Switch the power supply to the "Off" (sometimes "O") setting.
2 . Insert the end of one wire from a single pole, single throw (SPST) switch into the green wire of the ATX power connector (the largest power supply connector).
3 . Insert the end of the other wire from the SPST switch into the black wire of the ATX power connector. If your power supply has two black wires, connect the SPST to the black wire directly beside the green wire.
4 . Wrap electrical tape around the ATX power connector and wires from the SPST switch to hold them in place. Make sure there is no exposed copper or silver wire from the SPST switch wires.
5 . Turn the SPST switch to the "Off" position, if not already set. Plug the power supply into the wall outlet and switch it to the "On" (sometimes "I")setting.
6 . Connect any other computer components that you wish to operate without the motherboard, such as fans, drives or cards. Turn the SPST to the "On" setting to activate the power supply.
Hope the above information will be helpful to you.
Thanks.
Dec 01, 2010 | Compaq (243890-001) 250-Watt Power Supply
I think my power supply is dead. Computer unresponsive, no cooling fan, etc. Is there a way to test the output with a voltmeter? Thank you.
You can use a paper clip and jump the connection from the green wire to a black wire next to it, this will force the power supply to turn on. If the PSU turns on, the means your issue probably lies elsewhere in the system, like a bad power switch or connection.
Aug 21, 2010 | Dell HP-P2507FW Power Supply ** FREE...
Dell dimension 5510 it will not turn on, no
1/10th a volt? Nope.
Bypass the Power On switch. See if you have a bad switch first.
Then test the power supply. If the power supply comes on by bypassing the Power On switch, I'll bet you have a weak 12 volt voltage power rail.
1) Yellow wires are 12 Volts
2) Red wires are 5 Volts
3) Orange wires are 3.3 Volts
4) ANY Black wire is a Ground wire
They do sell power supply voltage testers, should you not wish to use a multimeter set at DC volts.
(0 - 50 Volt scale)
I prefer a multimeter.
A) ALL the light use less than 1 Watt
B) EACH fan uses 2 to 3 Watts
C) A typical Processor uses 55 to 125 WATTS.
You have to turn the power supply on, by jumping the Soft Power On wire to any ground wire.
This is also the way to bypass the Power On switch, to see if the switch is bad.
Do you wish to proceed?
Jan 15, 2010 | Dell Dimension E521 PC Desktop
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Dell power supply NPS-210AB will not turn on
Try switching it with one that you are certain works just to make sure it didnt blow or that your computer is working alright. or, using a multimeter, try and check for any current flowing to any of the connectors...
Jun 21, 2009 | Dell 210W Optiplex GX270 NPS-210 AB Power...
Gateway power supply
switching unit in powersupply sounds shot, if you want to test primary switching, un plug power from back, take main motherboard power socket off the board, take a paper clip and put it in the GREEN wire in the socket, and any BLACK wire, now (without touching the socket or having it touch anything else) plug power into the PSU, if the fans all fire up and spin, then the switching is fine, i would look at a fault on the board
Dec 03, 2007 | Computers & Internet
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
