Question about Coby Vertical Loading CD Player with AM/FM Radio Boombox
No am radio
I have a coby ktf-dvd-1093 ktf-dvd-7093 and can not get any am radio reception. antenna is properly installed according to the manual instructions.
I wound the antenna wires tighter and doubled them over. Got the radio going when I reinstalled these two wires to the connection in the back.
Posted on Jan 10, 2009
Coby buzzing sound in speakers when TV off
Check its audio output circuit for damaged component/s, provided, iv video is OK.
Jul 21, 2013 | Coby KTF-DVD1070
FM radio reception is poor. User manual suggests connecting an external antenna. Where do I connect it?
Hi, I think your units model number is AJ6111. According to the owners manual, the FM antenna is integrated to AC Power Cord. So you can not add antenna. But you can try to re arrange the cord and perhaps add an extension cord to see if reception gets better.
If this is not the unit you have, please try to provide the model number so I can look up the right owners manual and try to help you.
Good luck.
Mar 21, 2011 | Philips Under-Cabinet Alarm Clock Radio...
Where can i get a copy of the owners manual for Coby KTF-DVD1093 10 in.
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 16, 2010 | Coby KTF-DVD1093 Portable DVD Player with...
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
Factory radio reception failing
I would suggest installing what is called a filter capacitor.You can get these at most car audio shops or a electrolytic capacitor rated at 16v or higher and around 30uf (the capacity is not very important) you connect it from the Positive to the Negative on the radio. The idea being a capacitor will allow the A/C current (noise) to pass through to ground without going into the radio and this is usually the cause of poor reception.
Another possible cause could be simple a poor quality antenna, some manufacturers are going cheap on the antennas since most people don't listen to the radio anymore. You could try to screw an antenna off of a different car onto the base on this one and see if that clears up the problem, they are a some-what universal thread.
Jan 22, 2009 | 2003 GMC Envoy
Bad radio reception
Problem: Radio Reception is bad to non-existant. AM is usually worse than FM.
Reason: Antenna connector has come loose, and needs to be reconnected. This happens when a passenger pushes the carpet toward the firewall and disconnects the plug.
Affected Model Years: 1997, 1998, 1999, 2000, 2001, 2002, 2003
Permanent Fix:
1. First check to make sure the antenna at the back of the radio has not come loose.
2. Remove the plastic cover on the front passenger door threshold held in place by three pressure clips.
3. Peel back the carpet on the front seat passenger floor.
4. Locate the coax antenna cable running along the side.
5. Reconnect the two pieces of antenna that have come loose.
6. Roll the carpet back, and re-install the threshold cover.
Nov 01, 2008 | Kenwood KDC-119 CD Player
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
Coby Vertical Loading CD Player with AM/FM Radio Boombox Logo
128 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
