Re: Bluechip mobile file error-restore default will not...
Hi, did you manage to find a solution to this issue? The mobile i got for my grandmother is doing the same thing, can i cannot find anything in the user guide? Thanks
Have you tried a System Restore? Unplug, remove battery, plug in, try a reboot or a System Restore. OR, from the Command Prompt run a System File Check, using this procedure: http://support.microsoft.com/kb/929833
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
Shekhar KotianChina Mobiles "File Error Restore Default" I have got some china phones with "File Error restore default" what is the solution for this problem anyone to help???","type":22}">Like • • 5 hours ago
China Mobile Hong KongHi
Shekhar Kotian, i am sorry that we dont have the information about this
Handset model, i suggest you to contact your own handset provider to
get more details, thanks!58 minutes ago • "}">Like
If the keypad is not working you can remove the battery keep aside and check if the phone restores.If not the software must be reinstalled provided this might solve unless if has issues of the motherboard having errors. Contact micromax service
a simple batch file could be used
down.bat
@echo off
IF "%1"=="" GOTO DEFAULT
IF "%1"=="a" Shutdown -a
GOTO END
Shutdown -r -t %1
GOTO END
:DEFAULT
Shutdown -r -t 30
:END
This batch file accepts the inputs as follows
"down.bat" This will shutdown in 30 secs and is default
"down.bat 120" This shuts down in 2 mins
"down.bat a" This aborts any shutdown operation.
Hope this is what your after
