Question about Texas Instruments TI-30X-IISTK Scientific Calculator
Unable to get any response other than syntax error
Have a new TI30XIIS and all efforts to get it to work fail yielding only syntax error
Thanks Doug
  • 1 more comment
  • Anonymous Feb 05, 2009
    syntax error
  • Anonymous Feb 16, 2009
    this is so ******* annoying
  • Anonymous Mar 21, 2014
    unable to restart several windows XP Pro services like RPC,Installer and dependency group in services.msc. when I try to open the service properties to open task option menu don't get any response.
Push the button that says "2nd", then push the number "0". This will reset the calculator. After resetting, it should work again.
Posted on Oct 08, 2009
My son cleared the memory to fix the syntax issue.  The solution involved hitting the delete and memory key at the same time....
Posted on Jan 10, 2009
Cannot view my own website. it reads: "Parse error: syntax error, unexpected $end..." in my index.php file. HELP
Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Locate the syntax error manually. Step through each section of your code. Most code will be sectioned off into groups or functions. Carefully proof your code. Be sure to pay close attention to how lines are grouped. A common syntax mistake is incorrect grouping.
For instance, if you have an If Else statement embedded in another If Else statement, be sure the embedded statement is surrounded by a separate set of parenthesis or brackets, depending on your language. Double-check notes sections. Notes are only for the developer to see. However, if the syntax isn't correct, the notes may become part of your application, which may not agree with existing code. Ensure the syntax around your notes is correct. Run a debugger if possible. This will make locating errors much easier. A debugger will be found under a menu such as Debug, Run or Tools or as part of your SDK's toolbar. Allow the debugger to run. Errors will be listed at the bottom or right side of your screen. Many debuggers will highlight possible errors in your code as well. A line number, along with the possible error, will be listed in the error message. Locate your syntax error if the debugger isn't correct. Sometimes a debugger will show you where your application stopped working correctly. The syntax error itself may be above or below the line listed in the debugger message. Check all syntax within the surrounding area, especially within the line's function. Run your application after correcting the syntax error. Check every possible function of your application to ensure it works correctly. If you find a problem, double-check the syntax in your code that surrounds the problem area. For instance, if your application has a log-in screen that isn't accepting passwords correctly, check the code for the log-in screen. Remove Syntax Error syntax error typically occurs when the Web page you are loading causes a script error in the browser. This is caused by incorrect code that displays an error message or results in a Web page that does not load correctly. You can remove a syntax error by making a change to the settings of your Web browser. Common Web browsers that can experience this type of error include Internet Explorer, Mozilla Firefox and Safari.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect.
b>
b>
Apr 06, 2013 | Computers & Internet
I keep getting a box on my screen every time i try to do anything. it says EvalInsandbox:SyntaxError:syntaxerror
Correct a Syntax Error Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect. Hope this helps.
b>
b>
Dec 06, 2012 | Mozilla Firefox
I GET ON FACEBOOK THEN I GO TO WSOP SITE CLICK TO PLAY AND NOTHING HAPPENS OR I GET A MESSAGE TELLING ME THERE IS A SYNTAX ERROR (12) . I DON'T HAVE A CLUE WHAT THAT MEANS. ANY HELP WOULD BE APPRECIATED
syntax error - an error of language resulting from code that does not conform to the syntax of the programming language; "syntax errors can be recognized at compilation time"; "a common syntax error is to omit a parenthesis"...
("syntax error" is a kind of...):
programming errorsoftware error (error resulting from bad code in some program involved in producing the erroneous result)
Apr 25, 2011 | Playdom WSOP Poker
Linear culculation reset as ( 5+5/2=5 not 7.5 ! )
I have no idea what you mean by linear calculation reset. So I will not address it. As to the operation, (5+5[a b/c] [=] my calculator did not scream Syntax Error and dutifully supplied the missing parenthesis. The result is 7u1u2 or 7 and 1/2
I suspect you entered (5+5) [a b/c] 2 or (5+5) [/] 2 [=]. On my calculator the first key sequence yields 7u1u2, while the second key sequence yields 7.5
Mar 25, 2010 | Casio fx-300ES Calculator
Can you correct my error message? command line option SYNTAX ERROR I get this message when I try to open a pps file. I have Microsoft Power Point installed on the computer. Thea.
In computer science a syntax error ( IPA: /ˈsɪntæks ɛrə(ɹ)/ ) refers to an error in the syntax of a sequence of characters or tokens that is intended to be written in a particular programming language.
For compiled languages syntax errors occur strictly at compile-time. A program will not compile until all syntax errors are corrected. For interpreted languages however syntax errors cannot be detected until runtime and it is not necessarily simple to differentiate a syntax error from a semantic error.
A syntax error may also occur when an invalid equation is entered into a calculator. This can be caused, for instance, by opening brackets without closing them, or less commonly, entering several decimal points in one number.
copy and paste this link in your internet address bar for more information:
http://www.google.com/search?q=SYNTAX+ERROR&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
feel free to ask any other questions
Oct 13, 2009 | Microsoft Windows Vista Home Premium with...
Printing syntax
'declare the variables
Dim Connection
Dim ConnString
Dim Recordset
Dim SQL
'define the connection string, specify database driver
ConnString="DRIVER={SQL Server};SERVER=yourServername;UID=yourUsername;" & _
"PWD=yourPassword;DATABASE=yourDatabasename"
'declare the SQL statement that will query the database
SQL = "SELECT * FROM TABLE_NAME"
'create an instance of the ADO connection and recordset objects
Set Connection = Server.CreateObject("ADODB.Connection")
Set Recordset = Server.CreateObject("ADODB.Recordset")
'Open the connection to the database
Connection.Open ConnString
'Open the recordset object executing the SQL statement and return records
Recordset.Open SQL,Connection
'first of all determine whether there are any records
If Recordset.EOF Then
Response.Write("No records returned.")
Else
'if there are records then loop through the fields
Do While NOT Recordset.Eof
Response.write Recordset("FIRST_FIELD_NAME")
Response.write Recordset("SECOND_FIELD_NAME")
Response.write Recordset("THIRD_FIELD_NAME")
Response.write "<br>"
Recordset.MoveNext
Loop
End If
'close the connection and recordset objects to free up resources
Recordset.Close
Set Recordset=nothing
Connection.Close
Set Connection=nothing
May 16, 2009 | Microsoft Windows Vista Ultimate Edition
Cannot load office outlook 2003
Try uninstalling Outlook then reinstalling it. Good Luck!
Nov 15, 2008 | Microsoft Office Outlook 2003 for PC
When I synchronize my Palm Vx with Outlook, everything except Notes synchronizes. How do I get Notes to synchronize as well?
he Chapura PocketMirror support site is a great resource for finding any solutions with regard to the Outlook conduits for handhelds like the Palm Vx.
Sep 11, 2005 | Palm Vx Handheld
Texas Instruments TI-30X-IISTK Scientific Calculator Logo
848 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
