Question about Sony KV-32S26 32" TV
1996 32" Sony Trinitron Suddely looses power
Never had a problem. Suddendly goes dead as if turned off. No response from the TV panel or the remote. Any suggestions would be helpful.
  • 934 Answers
Crismo, The most common problem for what you've described could be a failure of the HOT (horizontal output transistor Q502 which also includes the following components as well. Q601 & Q602 (2sc4834)sony p/n#8-729-019-49 R607 (sony p/n# 1-202-933-61/ .1@1/2 W) C615 (sony p/n# 1-136-759-11/ .039mf/630v) So common is this type of failure that Telematics used to sell a kit with these parts as a primary repair for this type of failure. The HOT, both vdr's, the resistor and mylar cap are not expensive, the but installation and testing is quite involved. These may not be the only parts in solving the problem and if you're lacking any skills or equipment to make these repairs yourself I'd strongly suggest having a reputable shop do the job for you... It shouldn't be too costly and quite a number of shops may have the parts necessary on-hand. This model sony is a good Tv and the repair would clearly be worthwhile. Good Luck! Bill
Posted on Jun 04, 2007
How to turn standby off
The TV circuit may have detected a problem within its parts. You may have to check some leaking capacitors in the board or loose solders or burned components just to make sure. Normally leaving the TV unplugged overnight should reset it.
Sep 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont turn on
Ur high voltage is dead,the FBT,the flyback transformer is dead.The big black block of plastic with a red wire with a cap hook to the CRT(tv tube).
Mar 19, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
No listing of 3 digit codes for Sony Trinitron, RCA universal rem
  1. Turn TV on.
  2. Press and hold TV button and Power button until light stays on.
  3. Release both buttons.
  4. Aim remote at TV and press the power button every 5 seconds until TV turns off.
  5. Press stop button at bottom of remote.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
2000 Sony Trinitron TV - Ghost activity, off & on power, now dead
Check and replace the T'Con board. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 06, 2017 | Sony KV-27S42 27" TV
1993 Sony Trinitron 27"
as set is dead the problem is in power supply or horizontal section. though it is a simple &less time taking. but if you have no TV repair experience, or any experience tracing circuit flow with a schematic, call in a tech to assist you with this repair. This tv set is not the place to be experiementing inside of. You probably have bad capacitors and transistors in the power supply or the sweep power supply. Good Luck
Sep 30, 2007 | Televison & Video
Re: Sony KV-24FS120
your problem in system control ic section related to stand by pin check ckt related to stand by section in remote ic check power to system ic loose coniact in remote or system ic thanks
Sep 09, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
1996 Sony 32" Trinitron - Suddenly lost picture and sound
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Jun 04, 2007 | Sony KV-32S26 32" TV
Sony Trinitron 36" TV
Try a "hard reset"===unplug AC for a long time, like overnight.Let me know if there is any change.
Mar 07, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony Trinitron KV-28WS3U Dies
B+ over current protection (OCP), unit goes to the standby mode. Could be a short in the power supply of any of the circuits.
Nov 05, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV-32S26 32" TV Logo
42 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
