Question about Sony KV-32S26 32" TV
1996 Sony 32" Trinitron - Suddenly lost picture and sound
Never had a problem. Set was on and suddenly went dead as if the set had just been turned off. No response from TV panel or remote. I've reviewed similiar situations on the knowledge board and it seems as if my first response should be to check the internal fuse. Any suggestions would be helpful
  • Anonymous Feb 23, 2008
    sony 32" no steps taken. tv went comletly dead..never had any problems before. too heavy for us elderly to carry to have repaired. do you have any solutions?
    Scholar:
  • 77 Answers
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Posted on Jun 04, 2007
Sony Trinitron KD-28DL10U switched off suddenly to standby mid programme and won't come back on.When trying the remote on I can hear it click on and immedietly off again.Switched off at set and socket and...
Hello
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
Nov 21, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sudden death
Take out ur antena,cable ect.. input have any noise.Or tv could have dead video.
Aug 16, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Audio went dead suddenly and no sound with any channel.
Audio went dead with no sound on any channel. Signal was breaking up (picture was tiling). When tiling stopped, sound went dead.
Apr 01, 2009 | Televison & Video
Picture is all different flashing colors
Maybe you put magnet near to your TV or something that can produce magnetism.... if not the deguassing system is not functioning anymore. .. bring your unit to near service in your place.
Apr 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Blinking Chanel 3
I have a 36 Trinitron, the sound and picture went but the red light just keeps blinking, any ideas? Please ....
Feb 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV32s45 sudden failure
heard a pop sound -- then the set went dead -- no lights, no nothing, and then there was a slight electrical burn smell coming from the back of the set :(
It's an old 32" set
Nov 19, 2007 | Sony KV-32S45 32" TV
Picture and sound went out suddenly on a Sony KV-35S40
sony has problem with bad picture tubes as well as flyback transformers .if you have shorted hori output then replace it if set shorts it out again your looking at bad flyback transformer as well as maybe leaky tube.
Oct 27, 2007 | Sony KV-35S40 TV
No picture and no sound,
Something shorted and shut your set down. Most likely the high voltage transformer shorted which also shorted the horizontal output transistor. Stargazer
Aug 01, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-32S26 32" TV Logo
189 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
