Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a HDTV1080 integrated Mitubushi TV.  Tried to turn on the tv but the timer green light started blinking and has not stopped and tv will not turn on.  What is wrong with this tv?
    Sergeant:
    Champion:
  • 227 Answers
You gonna need some technical skills to replace the parts that are bad on your tv,but anyway check the power supply first,look for some swallen capacitors.and replace them that is going to be your first step.
thanks.
caypianan@yahoo.com
Posted on Jan 09, 2009
My mitsubishi medallion HDTV1080 won't turn on anymore. The green timer light keeps blinking and thats the only thing it does. Please help.
The tv power supply board it is dead.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 24, 2011 | Televison & Video
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
When i plug in my tv the screen stays black and wont come on
Hi my name is Roety,
I can help you with your issue ,
Your Mittsubishi has a system the will cause the green light to blink for 70 seconds when first plugged in, if the green light never stops blinking it is either a power supply issue or a stuck keyboard button.
So do the test and reset it to see if the light stops blinking or not.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Apr 15, 2010 | Televison & Video
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Blinking timer light will not turn off.
You most likely have a fault in the defelection circuitry that is causing this. A repair is needed, none-the-less....accordianman
Jan 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Pull out the power cord from the outlet for about one minute and then replug it. The blinking will restart for about a minute or less and then the set will turn itself off. You will then be able to turn it back on in the usual way with the remote or power switch.
I believe this is caused by a power surge or a momentary power outage.
SG
Dec 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
