Player freezes when i turn it on to play songs
My philips gogear player won't work when i turn it on, theres a little white box that comes up in the upper left hand corner with a bunch of numbers in it and i can't get it to play anything. or turn it off unless i reset it.
  • Anonymous Jan 10, 2009
    My Philips Gogear freezes too. I wonder if there is an update to the software, can Philips also supply me with a way to add different playlists, and name my music, are there dowloadable programs for the internal hard drive on the mp3 player..?
I think windows vista / windows 7 solves this issue pretty well.. i had the same issue..
"sayin something like... use device manager and repair your GoGear "
but i cleared this issue so simple in windows vista / windows 7
First Reset the System.
don't install the software that comes with the player to PC, just connect the device as a "Mass Storage Device"
U can easily format the Player drive so easily, than u can do that in XP no more :( , Vista / 7 Formats in seconds.
this is as simple as it is.
Trust me , it worked in my very first try on Vista.
Regards,
Cruise.
Posted on Mar 01, 2009
I have a phillips go gear MP3 player and when i turn it on it freezes only the words www.phillips/welcome.com screens shows. how to i fix this?
Hello
Your GoGear is freezing because there is an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
Sep 02, 2010 | Philips SA3025/37 Flash MP3 Player
Crashes after playing a few songs..
Check the battery of player. It may require replacemnt. (ehteshamhusain@gmail.com)
Jul 20, 2009 | Philips GoGear SA5285/37 Digital Media...
My Philips SA52xx GoGear MP4 Player won't start up. It just starts starting up and freezes on GoGear, it also makes wierd crackling sounds when playing music... My Philips GoGear used to start up within 10...
if it has too many songs on it try deleting some of the songs off the player, and if thats not the case, stop using it for a few days then try to turn it on again
May 31, 2009 | Philips SA3125\02 MP3 Player
Tunes that it said was in player but wont play
The Philips GoGear's are not compatible with iTunes. You need to download mp3 files or files that are in UNprotected WMA format into the player using Windows Media Player, or else the player will not recognize them.
-Tha Mp3 Doctor
Mar 17, 2009 | Philips GoGear SA5285/37 Digital Media...
Downloaded songs but won't play on go gear 3020/37 how do i fix
First try opening the gogear device and click on music right after the welcome screen. Select either "All Songs", "Artists" or "Albums" to find your songs. If you downloaded your songs, they should display on the screen of philips gogear, then you can select them to play on your headphones
Only some audio formats (.mp3 .wav and .wma will be play on philips gogear SA 3020/37)
Feb 23, 2009 | Philips GoGear SA3020/37 MP3 Player
Philips GoGear Glitch
Make sure that there is available memory. If there is, then you will need to do a firmware upgrade and reload the songs onto the player. If you already have the latest firmware, then you will need to reformat the player either in Windows Media Player or the computer. If that fails, use the repair function in the Philips Device Manager.
-Tha Mp3 Doctor
May 28, 2008 | Philips GOGEAR SA6045 MP3 Player
Freezes/changes song randomly during certain songs
i would suspect the song to be corrupt or you could try downloading the new firmware
May 15, 2008 | Philips GoGear HDD6330 MP3 Player
It freezes up and wont read
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Dec 28, 2007 | Philips SA5125/37 MP3 Player
Phillips 8gb mp3
There is a step left out of the repair instructions on the website/device manager itself:
-Tha Mp3 Doctor
Oct 21, 2007 | Philips HDD1630 MP3 Player
My Philips MP3 Player Won't Play My Songs. What Do I Do?
-Tha Mp3 Doctor
Sep 27, 2006 | Philips HDD1630 MP3 Player
57 people viewed this question
 Grubhead
Grubhead
