Question about Whirlpool LER5636P Electric Dryer
Dryer won't start
I have a Whirlpool electric dryer, model # LEQ9857LW0. The belt just broke and we replaced it last night. Dryer lasted one cycle (clothes were still really damp) and then would not restart. When I push the start button, it sounds like the motor is running, but as soon as I remove my finger, it shuts off. The light comes on when I open the dryer door, so I know there is power. Any idea what's wrong now?
Thanks!
  • zwuollet May 20, 2009
    I have a whirlpool electric dryer LEQ9857LW0 that will not start. It will sound like the timer is going but when you push the start button it will shut off. It worked for one load than the next it did not. There is power to it and the dryer light will turn on but nothing happens
  • Dean Rhymer
    Dean Rhymer May 11, 2010
    Is the drum actually turning ? open the door hold down the door switch and have someone push the start button.
  • 979 Answers
I believe you have lost a leg of power.Check you breaker and then the wiring in the back of the dryer.
Posted on Jan 17, 2009
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Jun 21, 2014 | Kenmore 659 Electric Dryer
Whirlpool dryer model wed7300xwo gets to last 3 minutes then trips breaker
generally the last 5 min are a cool down part of the cycle and there are no elements energized at that time, which cycle are you using and how long do you set the time for
Dec 01, 2013 | Whirlpool GEW9250 Electric Dryer
Dryer will not turn on. I hear a faint electrical sound when I push the start button but the dryer will not start. It worked fine through the last cycle. This is a stacked washer/dryer model & the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Aug 21, 2010 | Whirlpool LER4634J Electric Dryer
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
The belt broke on my Whirlpool super capacity dryer (23 years old)model number LG7686XPO. we are able to get the belt could you plase send us a diagram of how the belt goes on? and some directions...my...
Your belt will use one of these configurations. Just right click on the picture, copy & paste it into a document or save as and them open it with a photo viewer.
Jun 30, 2009 | Dryers
My LG DLE2514W electric dryer starting making a squeaking noise at the end of a drying cycle last night. After letting it sit for over an hour, started the dryer back up and the squeaking noise came back...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
vciku
Jun 29, 2009 | LG DLE2514 Electric Dryer
Whirlpool gas dryer model lgr3634jw0 won't start. Dryer is used about once/week during winter months. Was operating properly when last used last week. Think an electrical component has failed but not...
After several days trying to locate the problem, I decided to junk the machine & buy a new product. The machine was 8 years old and I accidentally broke the igniter while trying to dissamble the various pieces of the machine. The igniter wasn't the problem nor was the problem ever definitely diagnosed. With this machiine's relative little usage & unresolved electrical failure, the machine reflected its poor quality of manufacture.
Feb 19, 2009 | Whirlpool Dryers
Whirlpool LER3624JQ
check the breakers,check the belt, check the heating element,and check door switch majke sure it isnt loose or broke or something.All dryers are fairly uncomplicated.Last check wiring and motor.
Oct 16, 2008 | Whirlpool LER3624JQ Electric Dryer
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
This can be due to malfunctioning of any of these 4 devices..
1)Heating element
2)Thermal fuse
3)Thermostat
4)Timer motor
For more info and troubleshooting checkout this link..
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 22, 2007 | Whirlpool LER4634J Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
125 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
