Question about Daewoo DTQ-20U6SC 20" TV
Computer to Television
I am trying to run the video from the laptop to the TV but I can't get the video to transfer! What am I doing wrong? Jeremy
  • Jeremy Peterson Jun 04, 2007
    it is just an RCA connection
    Problem Solver:
  • 18 Answers
In control Panel you must turn the TV option active
Posted on Jun 04, 2007
  • 883 Answers
Describe laptop connector..is it S-video?
  • Marty marty Jun 04, 2007
    try another tv or set the laptop's tv output to NTSC format....(and not PAL)
How can I transfer long videos from iPhone to laptop?
Ibrahem, Check the attached links,instruction and guides how to transfer your vids. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 30, 2016 | Cell Phones
How do l connect computer to tv
In order to connect your laptop to a television or computer is actually a fairly easy step and simple. Try checking your laptop or computer and your TV to be able to find out information about the exact connector types to choose an appropriate input to the device. It is almost the same as when you are going to connect a DVD player to your TV. You have to figure out the input of the device to be connected to your television.
Some computers have an S-Video port that can be connected to the S-Video input on the TV screen by using the S-Video cable is relatively inexpensive. To get a more recent picture quality, you can connect your computer to the TV using a VGA port or through a DVI or HDMI cable that provides support on the TV.
Oct 31, 2013 | charter.net
CONNECTION WITH THE TELEVISION SHARP
are you saying that you cant see the desktop icons on your tv? maybe you need to adjust the resoloution on the computer screen to fit the the resoloution/size on your tv. try lowering the resoloution of your computer
Feb 28, 2013 | Lenovo ThinkPad T400 - Intel Centrino 2...
How can i display a portable swivel projector from my laptop using a vga connection? Once im connected all i see is a color bar screen on the wall, do i press something to enable the picture?
There are different types of video outputs which your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Weigh the strengths and weaknesses of each types of video input and output. VGA projectors are the most common type, indeed it is likely that any projector in current use will have a VGA input. However, VGA video offers the lowest resolution of the these three types. S-Video offers a higher resolution than VGA, but is prone to screen flicker, especially when you are connecting your laptop to a power supply while presenting, rather than running off the battery. HDMI offers the highest picture quality of the three, and supports audio data transfer as well. However, know that HDMI-equipped laptops and projectors are more expensive than those that utilize the other video transfer formats.
Choose a video data transfer standard best suited to your price range and needs. VGA is always the safest bet, but if you are purchasing a new laptop computer, try to find one within your budget with an HDMI output as well, as it will provide the best quality and allow you to transmit audio without the use of extraneous equipment. S-Video inputs are found on nearly every LCD and Plasma television, meaning that if you are giving your presentation connected to a television rather than a projector, this is a viable option as well.
Make sure you know how to tell your computer to recognize that you wish to use a projector as a secondary video output device. On Windows-based laptop computers, this usually involves pressing the "Function" (or "Fn") key, followed by one of the numbered "F" buttons along the top of your keyboard. In most cases there will be a graphic of what looks like a television screen on the correct "F" key (e.g. "F4"), but if you aren't sure consult the manual that came with your specific model.
Connect your video cable of choice to your projector and your Windows laptop, turn the projector on, and press the correct function key. If you have a solid video card, pressing the same key combination a second time will allow you to view your laptop's screen both on the computer itself and as a projected image simultaneously.
Connecting a Macintosh laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
Try a dry run of your presentation using your own laptop and the same projector you will be using, if possible. It pays to be prepared, and your audience will be able to tell if you are fumbling around for the right function keys on the day you present. Your confidence will help you start your presentation off with a bang, and it will show.
Aug 30, 2010 | Toshiba Satellite A135-S4527 Notebook
I can not connect laptop with projector
Instructions
Things You'll Need:
Laptop computer equipped with a VGA, S-Video or HDMI output.
Overhead projector with the applicable input.
VGA, S-Video or HDMI cable.
Software to ready your content for presentation at the correct screen resolution.
DVI-VGA adapter, if you are using a Mac.
Step 1
Learn the different types of video outputs your laptop may or may not support. The three most common types of video outputs used with overhead projectors are Video Graphics Array (VGA), Separated Video (S-Video) and High Definition Multimedia Interface (HDMI). You need to make sure your laptop has the correct output corresponding to an input on the projector you will use.
Step 2
Step 3
Step 4
Step 5
Step 6
Connecting a laptop computer to an overhead projector can be a little trickier. You will need a special adapter to connect to a projector using VGA, as well as the standard VGA cable. This is called a DVI-VGA adapter, and is available both from Apple and other electronics vendors. Plug the adapter to the DVI port on your Macintosh laptop, then plug the VGA cable into the projector and the adapter. Turn on the projector, then press and hold the "F7" key on your Mac. You will be up and running in no time.
Step 7
Hope this helps
Aug 01, 2010 | Acer PD100 Multimedia Projector
VGA cable from the computer to the TV the TV shows no signal
Tell me model of your computer and TV. How do you connect PC to TV, with s-video cable (looks like circle) or width two colored cables? Try to adjust video-card driver. There must be function like "find my TV".
Mar 27, 2009 | Sony BRAVIA KDL-40V3000 Television
Why won't my tv display my computer screen
Hi. The best way to hook your computers display to your LCD screen will be to use the VGA input socket. If your video card can support both S-video input and VGA, you can use either one but, the VGA is best for optimal resolution. This is the easy way to do this. Step one, connect the VGA cable to the computers video card and then, run the other end of this same cable to the VGA input slot on the LCD screen.Step 2, next you will make sure that the LCD's input selection is selected to show what is being transferred from the CPU video card by using the input button on the lcd remote control. The lcd(your tv) should be on VGA or PC input signal. Step 3, now, you Will have to also make sure that your video card is set to transfer this signal as well by pulling up your video cards software window and switch to the proper options. once this is done, you should get a signal. Be sure to use the VGA input/output ports on both the lcd television and your cpu for optimal transfer of the video stream. Here is a pic of your back panel. use the input port labeled I for good PC input quality.
Mar 24, 2009 | Proscan 32LB30QD 32 in. LCD TV
Hook up laptop to computer
Your computer may be running at a higher resolution than is supported by your TV. Lower your laptop's resolution to 800x600 and try again. If it works, you may be able to raise the resolution higher, perhaps 1024x768.
To change the laptop's resolution, go to the desktop and right click and select "Properties". Select the "settings" tab. You will see a box labeled "Screen Resolution", slide the slider to the left as far as possible. Then, plug in the laptop to the TV and select the appropriate input from the TV.
Hope this helps.
Jan 03, 2009 | Dell Latitude D600 Notebook
Connect laptop to RCA - F25305
What kind of computer do you have? There wuold have to be a video out or SVHS plug out from your computer. And a video or SVHS input to your TV. If both are physically available then there should be a computer configuration so your laptop can output to your TV.
Sep 17, 2008 | RCA F25305 25" TV
Transferring video and sound from my lap top to my television set
From my understanding.. S video is just another way to output video from your laptop to your tv.. as for sounds you'll need a cable that connect to your earphones or your laptop to the audio input of your tv.
Hope this will help you...
Jan 06, 2008 | Acer Aspire 3680 Laptop
Daewoo DTQ-20U6SC 20" TV Logo
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
