Question about Toshiba 36AF41 36" TV
Toshiba television is black picture
The picture is dark to the point of not being able to see the picture of the vcr while playing.You can hear it but not see the picture. It is also hard to see the menu because it is so dark.
  • 700 Answers
If this just happens while vcr is playing. Check the vcr. Did you happen to adjust its brightness and contrast settings. If things doesn't change. Then if this model is a crt type could be adjustment on its flyback transformer is needed tweaking slowly its screen knob or tweaking also its focus knob until you got it to the level of viewing it correctly.
But be aware, hazardous voltages inside it. Or let th technician set it for you, its a minor adjustment.
Posted on Apr 12, 2009
Why does my combo tv/dvd only play dvds in black and white? is it broken?
Check its settings. Get into its menu, and select picture settings. Set the color system to 'Auto' there. If wrong setting is done there, only B/W picture will be displayed.
Aug 26, 2012 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Vcr sound but no picture
After checking the connection, played a pre-recorded tape and the picture was displayed gradually. After about 5 mins picture was completly restored. Lost of picture was due to dirty tape heads.
Mar 22, 2009 | Panasonic TH37PX60 37 in. Plasma...
DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Dec 18, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Vcr problem
Did you try cleaning video heads? Most obvious problem. Do you see the picture out of the VCR while recording? That would rule out cables, switches set wrong and most of the electronic circuits.
Oct 15, 2007 | Panasonic AG-1980 S-VHS VCR
Quasar tv/vcr combo vv2009
clean the head of your vcr if that does not work then you will have to call in the tech to look into your problems goood is probably the color circuit
Apr 28, 2007 | Quasar VV2009 Combo
Picture gets dark and light
try the same brand vcr 0r dvd some brands will not work will with other brands.
Dec 30, 2006 | Emerson EWC1304 13 in. TV/VCR Combo
Picture keeps trying to black out
Hi I have seen this problem before, and it was the video processor. I have seen the picture fade to black, then come back, and also fade to green. The cost to repair is prohibitive unless you could find a shop that perhaps has hung on to a unit that was hit by lightning, and only has a blown power supply. The only ray of sunshine I could offer, is if you recently connected your unit to a vcr, because the effect you describe is also what appears when you try to play a dvd that is copy guarded. If your DVD player is connected to a vcr then to the television, take the VCR out of the loop, connect straight to t.v. and all will be well. Goog Luck!
Jul 16, 2006 | Toshiba SD-K741 DVD Player
Hitachi 23" tv/ toshiba vcr
Sounds like a problem in your VCR IF what your saying is when the screen goes dark and you turn off the VCR then the screen on the tv returns to normal?? Does this happen with the vcr on and the tape not playing?? No Ok you have a problem in the video processor Ic or the circuit but most likly the IC as Ive seen this already twice in a toshiba VCR. No if it happens even when the VCR is on but the tapes not plying and the vcr is sitting, and the screen fades The problem is the on screen disply IC in the vcr. seen this a dozon or so times already. Vcrs no a days are not worth the money to invest Unless you got a really good one from the past, BUT you can by a good on for these times for well under 100 bucks . Good Luck
Jun 06, 2006 | Hitachi 57G500 57" TV
Toshiba tp50f60
1. Check the TV's horizontal and vertical hold. 2. If there is a VCR connected: Shut off the VCR. If the problem clears up, the VCR is not properly ?fine-tuned.? Turn the VCR on and troubleshoot the VCR problems. 3. If a converter is connected to your TV and VCR: The VCR needs to be on channel 4. VCR may not be ?fine-tuned? to channel 4. Locate and adjust the fine-tuning mechanism until the picture comes in clearly. The <3/4> switch may be in the wrong position. Locate the switch on the back of the VCR and set it to <4>. 4. Check the fine-tuning of your TV. good luck :-)
Jan 11, 2006 | Toshiba TP50G60 50" Rear Projection...
Toshiba 36AF41 36" TV Logo
107 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
