Question about Epson Stylus CX6400 All-In-One InkJet Printer
Paperfeed on sx200 epson
Hi
i have an epson sx200 and use it regulary. however today i can not get the paper to load into the feed at all. it has taken me 3 hours to print 4 pages. it goes to load the paper then flicks it back and says paper is not loaded correctly. im starting to get the hump and gonna chuck it soon. any ideas guys?
  • nathanfenn Jan 18, 2009
    thanks nige.
    back up and running
  • Anonymous Feb 23, 2009
    paper wont feed and ink leaking out below printer its going to get binned soon
    Novelist:
    Sniper:
  • 68 Answers
The rubber grabber has got out of position.
Switch printer off.
Take all paper out of the feeder, put your hand in and you'll feel a rubber semi-circle, rotate (push) it toward the back of the printer until you can feel the rubber part disappear, load paper and switch the printer on and it should reset itself to the correct position.
Sometimes you have to press down slightly on to the paper weight sensor to unlock the grabber.
Try it and see how you get on.
Nige
The INK Store
http://www.the-inkstore.co.uk
Posted on Jan 17, 2009
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
Paper feed not working on Epson r300
If the paperfeed works when you "help" it a little, most likely the feed rollers simply need cleaning. We often suggest taking a little alcohol and spraying it onto some paper, and running it through several times, then running clean/dry paper through to finish. If the printer isn't even trying to load paper, possibly the paper sensor is blocked with dust, and blowing the insides of the printer may help.
Jan 14, 2015 | Epson Stylus Photo R300 InkJet Printer
Paper feeding problem
You need to replace the feed and transfer rollers. They dont cost a whole lot
Dec 23, 2013 | Epson STYLUS SX235W
How do i print onto acetate using an epson sx200; it doesn't recognise any paper... thanks
Some printers use a light sensor to tell if paper is loaded or not. If printing on clear acetate, try loading a regular sheet of paper under it. It should pull the acetate sheet through and leave the regular paper in tray. Since the Epson sx200 is an inkjet printer be careful not to smudge. I would allow a good 5 to 10 minutes to dry. Good luck!
Mar 01, 2011 | Office Equipment & Supplies
Paperfeed problem. Paper is grabbed but winds up
Try to uninstall and reinstall your printer.
Perform a hard reset to your printer.
Clean your printer for dust that may cause sensor problem.
Replace your printers sensor assembly.
Sep 26, 2009 | Lexmark E232 Laser Printer
Jammed paper
Removed the new paper from feed slot, pressed the on button which allowed the `grabber` to release the jammed paper slightly and then was able to [with the aid of long tweezers] remove the jammed paper through the feed slot.
Regards
Geoff
Feb 04, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Epson Sx200- Paper wont feed
Just a thought,as I had a similar problem.The instructions are abysmal,but it may be worth having a look where you feed the paper in and squeezing the grey plastic gizmo,and moving it to the left to allow the paper to enter the feed properly.
Dec 26, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson DX6000 paper jam problem.
Shake the printer and turn it upside down.....Be carefull in doing so...
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Epson Stylus CX6400 All-In-One InkJet Printer Logo
516 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
