Question about Dell 1600n All-In-One Laser Printer
Poor copy quality
Copy quality is somewhat blurred. Not sharp
  • attorneybob Jan 09, 2009
    Are your originals clear, but copies gray & less sharp? When I bought the machine, all was great, but copy quality is now degraded.
  • 191 Answers
There are 3 reason if the copy gray & less sharp:
1) the toner you are using is not compatible very well with the cartridge unit if you changed other compatible toner.
2) the cartridge going near the life-cycle, (also cause print blurred)
3) the photo drum going near the life-cycle
you may try to change the quality toner (original factory). or
change the cartridge if it is out of the life-cycle
Posted on Jan 23, 2009
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    you may try more:
    4) clean laser lens cover and run calibration (skew) from your printer manu.
    any help for you please send a feedback thanks
Keyocera km 2560 poor quality copy but good quality report print
dear clean the platen glass and its cover. adjust the sharpness.darkness.image quality to text and photo.
your printer is in good condition.
thanks.
Mar 30, 2015 | Office Equipment & Supplies
Our Sharp AR-160 copy machine is 5 yrs old. We have had to have continued maintenance, most recently the "developer" was replaced and our copies still come out faded. How long should we expect...
Did they clean the laser unit?
You can play with bias to raise the copy darkness.
For start you can open the front door and right side way door, remove drum unit, and you will be able to see long glass above drum unit. clean it with the dry wipe or wet one but be sure to dry it.
By my experience it is a good low maintenance copier... if the preventive maintenance is carried out correctly, every 60 000 copies more or less.
Hope that helps!
Dec 27, 2010 | Sharp AR-160 Copier
I'm having complants that my faxes are blured
Most common cause is going to be you need to have the scanner optics cleaned. Hopefully you have a local repair guy that can do this for you. However you can buy new basic fax machine like this now days for $75 to $80 which might be cheaper than servicing the old one.
Here is a tip for you tho. Make a copy using your fax machine. The quality of your copy is the same quality that you are sending out via the fax. So if your copy looks good then your outgoing faxes look fine. If you get a poor copy then that poor quality is what is being sent out. So copy quality = fax send quality.
Good Luck and Thank You for using Fixya.
Dec 01, 2010 | Sharp UX 108 Roll paper Thermal Fax
MY COPIER IS AR5316 SHARP HAS POOR COPY QUALITY
check the devoloper. see whether toner is flowing free into the devoloper.for immmediate effect mix some toner to devoloper.
Oct 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
Copy quality is poor. Replace toner, drum and transformer?
when you say the quality of the text is poor I am assuming that your are describing the line print
FIX
IF FUZZY remove corona wire and clean with q tip diped in alcohol
If IMAGE OFFSET check fuser rollers emove pad and ad fuser oil
IF copies lite remove print cartridge and shake back and forth to get toner distributed
also examine photoreceptor sounds the shutter is not closing and causing image distortment
Jan 05, 2009 | Sharp AL 1631 Copier
Blurry bottom 2 inches of copy from IR 1600
Take a Normal,reduction and an enlarged copy(at any ratio) of a Newspaper in different size papers. Then check whether the blurred position is at the same position or not.If it is at the same position, check scanner for its free movement, there may be an obstacle which will not allow the scanner to move freely resulting in blurred copy. or else let me know.
Dec 27, 2008 | Canon ImageRunner 1600 Copier
Blurred copy
blurred copies usually come from the optics area,
when turned off and on does the zoom lens go to home position and back?
did you clean the optics and then had this problem, could be a misaligned mirror.
Aug 22, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-285 reporting code F2 and smeared copies
to find the sub code press start key,if it shows 04,then ic chip present in it gone bad,replace the toner ic chip.
Apr 20, 2008 | Office Equipment & Supplies
Print poor copy quality
Fuser pressure (2 green levers on fusing section) may be set to envelope position.
Mar 04, 2008 | Konica Minolta bizhub C250 All-In-One...
Dell 1600n All-In-One Laser Printer Logo
186 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
