Question about Lenovo ThinkPad T61p Notebook Intel Core 2 DUO T93 PC Notebook
Laptop battery charging problem
Plain and simple, i believe this is a motherboard error. The gist of the story...
I had left my laptop, a Lenovo ThinkPad T61p in my bag accidentally, i assume that when I turned it off some program was still running and it did not turn off. When i next opened my bag, which was an hour and a half later, the laptop was off and very hot, I let it cool down for about an hour or so, plugged it in and it worked fine, except for one thing. My battery will not hold a charge, or so i thought.
The battery report on battery information window assured me that my battery was in good condition, which leads me to believe that this is a motherboard issue. Since I am a college student, i cannot really afford the time to send in the laptop, thus i wanted to look for a quick-fix. Any help would be greatly appreciated.
  • 21 Answers
Excessive heat could ruin a battery. You might just want to get another battery for it (check ebay or Lenovo.com).
One other thing to try is to run it on battery until it is forced to shut down and then let it set that way without turning it off for half an hour to completely discharge the battery, then recharge it fully again. See if that might help refresh the battery.
Posted on Apr 07, 2009
Lenovo v560 laptop motherboard no power on
check you battery, try turning on with battery removed. try a new charger. check charging port to see if it is loose. if all these fail then motherboard is bad
Dec 28, 2013 | Lenovo Ideapad V560-43422gu,intel Core...
No battery detected message appears . The battery is not charging (although new one, replaced last week), and laptop turns off when unplugged
Hello
It will be best to get it repaired by the authorised service center for Lenovo at your twon. Its battery charging section circuit [inside the motherboard] is faulty.
Mar 10, 2012 | Lenovo ThinkPad SL500 - Intel Core 2 Duo...
Lenovo g550 orange flash 3 times
3 orange flashes means flat battery. If you have a faulty charger or charger socket on the laptop then the battery wont charge or power up with just the charger connected.
Look here:Lenovo
Feb 01, 2012 | Lenovo G550 Notebook
Lenovo x 60 tablet battery shows 0% available , not charging. its a new battery i bought.
If the laptop works fine while plugged in but stops working while unplugged, It's likely that either your laptop battery is broken or your laptop battery is not charging properly. Below steps can help you identify the cause of this kinda problem
1. Leave Power plug in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
2. Remove and Reinsert Battery
In some situations the battery can become loose. Removing it and then put it back into the laptop.
3. There is Some Software
Use battery utility to determine the total capacity of the battery. For example, Battery Care Software is a free software utility capable of doing this.
4. Refreshing Battery
Some laptop manufacturers allow for batteries to be refreshed through the CMOS setup.
If problem still there. try Replacing Battery or Power Adaptar.
still the problem persist take the laptop to Service Center
best of luck..
Jan 29, 2011 | IBM Lenovo ThinkPad X60 Motherboard -...
Just purchased a new Lenovo battery, and it has never charged to more than 33%, and now is at 0. One icon shows it is charging, another icon says it is plugged in (AC adapter), but not charging...Tried to...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 15, 2010 | IBM Lenovo ThinkPad T61 6466 Notebook
I have a new battery of my lenovo 3000 n200 yesterday i have charged it for 18 hours before use ... then used the computer on battery power ... when it reached 34% I have plugged the charger I got the...
Sep 01, 2010 | Lenovo 3000 N200 Notebook
My lenovo y500 laptop battery is not getting
hi! just a tip probably there is a problem on the power board, just a suggestion if your still on warranty might as well call lenovo tech support so that they could replace the defective part. hopr this helps! goodluck!
Jun 06, 2010 | Lenovo 3000 Y410 Laptop
Problem with the power supply or battery
This is a simple issue hopefully.
The battery is no longer able to charge.Buy a new one on www.ebay.com ($50-$75)
It could be also that the motherboard cannot charge it (less likely)
sincerely,
Sagacious1
Aug 07, 2009 | Lenovo IdeaPad Y530 Notebook
Battery problem-plugged in, not charging. Lenovo 3000 N100.Type:0768.Model:24U.S.no:L3LA215. Please offer a solution.
Had the same problem with a manufactured refurb, would go to 79 %, if you go to power options, change plan settings, change advance power settings, then to the Lenovo energy management tab, press the big enable Lenovo energy management, click on the blue gear to the left of the question mark, if "Optimize for Battery lifespan" is selected it will only charge the battery to 80%, change this to "Optimize for Battery Runtime" and it will charge to 100%
Feb 26, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo ThinkPad T61p Notebook Intel Core 2 DUO T93  PC Notebook Logo
144 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
