Question about LG Shine KE970 Cellular Phone
Problem with picture id!
I can't seem to use the pictures i got from my pc to work as my phonebook contacts image. Is there a certain file type that it needs in order to get to work? Everytime i try it always says "Not Supported" So what type does it have to be for me to use it as my phonebook contact ID? Please help getting frustrated.
Thank you
La Angel from Guam
    Sergeant:
  • 290 Answers
You need to copy your contacts from SIM to phone memory if you haven't already also the pictures should be .jpg
Posted on Jan 09, 2009
Hi, I have the Nikon Coolpix 3000 and I've recently had some problems. I have only had this camera since December; Several times I have tried to upload pictures and "this file contains no image...
You can try to reformat the sd card. Sometimes cards will contain data that disrupts the reading process.
Also, sometimes if you edit images on the pc, such as rotating them in Window's image viewer, it will rewrite the image as a jpeg that is unrecognized in the camera.
Lastly, check to see if the photos are being saved to the sd card or the camera.
Mar 10, 2011 | Nikon Coolpix S3000 Digital Camera
How do i allocate a certain ringtone to a caller
unfortunately in samsung j700...doesn't provide the facility u mentioned
but it allows user to assign particular ringtone and callerid for some group of contacts...
the group may have 1 or more contacts so saving each contacts in each seperate group may indirectly met ur requirement
By creating groups of contacts, you can assign
ringtones and caller ID photos to each group or send
messages and emails to an entire group. Start by
creating a group:
1. In Idle mode, press <Menu> → Phonebook →
Group → <Options> → Add.
2. Enter a group name and scroll down.
3. To set the caller ID image, press the Centre key
→ an image category → an image.
4. To set a group ringtone, scroll down and press
the Centre key → a ringtone category → a
ringtone.
5. Press <Save>.
May 24, 2010 | Samsung J700 Cellular Phone
How 2 transfer pictures taken on my LG KG800 into its phonebook
if ur trying 2 save the pics 2 go with ur contacts then veiw the photo u want then on ur phone press options and it should say put as pic id 4 contact if that doesnt work then click and edit ur contacts and it should say name number ext. and then picture id click on that and it will say photos or downloaded images if u still cant get it then idk wat 2 tell u but that is my advice
Jul 28, 2009 | LG KG800 Cellular Phone
I take a picture, it shows it on the display, but when i try to look at the picture it says "file contains no image..
Do you have a card in? That may be the problem or your cardreader is no longer working. It can be repaired. Contact Nikon on line at NIKONUSA.COM or you may contact an authorized service center. I know of one in Florida, 305-653-7355
Apr 20, 2009 | Cameras
WHEN NAME AND NUMBER ARE STORED ON THE PHONE, WHEN YOU CALL SOME ONE YOU SEE THE NAME SHOWING, BUT WHEN THEY CALL, YOU ONLY SEE THE NUMBER OF THE PERSON AND NOT THE NAME LISTED IN THE PHONE. IF YOU SET THE...
This usually happens when you have duplicate entries in your phonebook.
Depending on the model of you phone, You can have only the phonebook or sim enabled but not both to avoid duplicate entries. Or it might be that there is really 2 or more Names for the certain number. Just review your phonebook and remove the duplicates. That should solve your problem.
Hope that helps.
Jan 07, 2009 | Motorola Mobility RAZR V3
Phone book pictures
make sure the pictures are saved to the memory card or the phone's memory
Dec 01, 2008 | LG KG800 Cellular Phone
Yahoo 9 wont let me display a picture or change nickname
Go to folder
C:\Program Files\Yahoo!\Messenger\Profiles\[your Yahoo ID]\My Icons
It's a list of display images saved by YM. Remember the filename of your desired image.
Open your registry (click Start, Run.., type REGEDIT).
Trace the path
HKEY/CURRENT_USER/Software/Yahoo/pager/profiles/[your Yahoo ID]/FriendIcons
The value of Path should reflect the filename of the current display image in your YM. Change it to reflect the filename of your desired image.
Close the registry.
Restart YM.
Oct 08, 2008 | Yahoo Messenger
Samsung d900i
Create contact (Menu 2.3)
Use this menu to add a new contact to Phonebook.
Storing a number in the phone’s memory
1. Select Phone.
2. Change the settings or enter information about the
contact:
First name/Last name: assign a name.
Mobile/Home/Office/Fax/Other: add a
number in any category.
You can change the number type, or set the
number as the default for the contact by
pressing <Options> and selecting Change
type
or Mark as default number.
Email: assign an e-mail address.
Graphic ID: assign a caller ID image to alert
you to a call from the person.
Ringtone: assign a ringtone to alert you to a
Group: assign the number to a caller group.
Birthday: enter the person’s birthday.
Notes: add a memo about the person.
3. Press <Save> or [ ] to save the contact.
Storing a number on the SIM card
1. Select SIM.
2. Select New or Update.
3. Enter information about the contact:
Name: assign a name.
Phone number: add a number.
4. Press <Save> or [ ] to save the contact.
Mar 05, 2008 | Samsung SGH-D900 Cellular Phone
Picture ID on contacts
If the file is too large it may not work (esp if you are uploading).
Also, make sure that the contacts you want pictures added to are stored in the phone and not the sim card. You cannot add pictures to contacts stored to the sim because there just isn't enough space.
Feb 23, 2008 | LG Shine KE970 Cellular Phone
Picture ID with samsung U540
This might be a possible solution....as I have had the same problem, with 2 phones...
Finally, I went to another cell phone rep - and we FIXED the problem!
My cell phone numbers in my phonebook are all saved with "1-area code-phone number" ie: 1-555-555-5555. The problem came from when people were calling me, locally, their number would come in as are code-phone number ie: 555-555-5555. The cell phone couldn't match the caller ID perfectly, so it would alternate between blank pictures, black pictures, wrong pictures.
Re-save your numbers, without the 1, and it should work fine - well, it did on my phone! :) Good luck!
Jan 07, 2008 | Samsung SCH-u540 Cellular Phone
LG Shine KE970 Cellular Phone Logo
59 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
