Question about EliteGroup P4M800PRO-M Motherboard
ElitegroupP4M800pro, chrashes I just installed A new motherboard and processor. Did all the installs and re-installs and everything seems to work just fine with one exception......Deepending on what I run it will restart my system, not on everything just certain games apps etc. I checked the core temp as I have a laser and I checked on the computer thru everest and it is running cool. So what is the deal here?
  • John Pette
    John Pette Jun 04, 2007
    thank you all......I had a suspiscion it was the ram....
  • 883 Answers
Sounds like a memory or pageing file problem. are you sure the memory is compatible? re-check both the speed and the capacity (bytes) requirements. if ok, then ensure that windows is controlling the virtual memory without any user-defined settings. also, ensure your power supply has enough headroom. add up all the watts needed and then nearly double that sum to get to power supply. example: 200 watts needed, use 400 watt supply
Posted on Jun 04, 2007
    Problem Solver:
  • 18 Answers
You need to check your RAM settings or replace the RAM Good luck
Just installed a brand new motherboard for my dell computer, new processor and new fan, everything is working but the fan, what's the issue and how do I fix it?
is the fan plugged into the correct port of the motherboard?
Did you install the reccomended OEM motherboard or a 3rd party motherboard?
Aug 13, 2011 | Dell OptiPlex GX270 PC Desktop
Installed the motherboard in a new case, it worked fine in the previous case but now i can't get any video output from either the motherboard or the video card. Its almost all brand new hardware, I've...
remove the video card, then see if you can get video from the mainboard video output. You did get a processor that supports that hopefully, If that works you need to boot into the bios and set the PCIe video to have priority over the onboard video. Turn off the PC and install your card. See if that works and good luck.
Oct 26, 2017 | ASUS M4A785M (890552666775) Motherboard
My monitor will not come on with my motherboard
have you connected the power cable to the processor socket? this is the small square 4 pin plug with 2 yellow and 2 black cables. If this is not conected the cpu itself will not be running even though everything else is, and thus no monitor. If this is not the problem, try reaseating the memory and also check for the baord "grounding" on the chassis.More help ? http://www.motherboardsrus.net and use the contact us button, Chris
Jun 07, 2009 | Foxconn |648FX7MF-S SIS648FX Motherboard
Installed a new processor and now it wont work
Is that an upgraded processor? If it is, then somehow, it could be its configuration problem with the older processor on software side. Your previous installation of OS remember its past processor and reporting error.
You can try fresh installation. Just for the input.
Apr 04, 2009 | Abit Fatal1ty FP-IN9 SLI Motherboard
Intel DG31PR Motherboard not booting
You could try reseting the Bios settings using the jumper of the motherboard after installing the new Rams. Anyways ,its working, so don't do that now :P .
"If some thing is working, don't try to fix it" :) .
Jan 28, 2009 | Intel DG31PR Motherboard
This is a new install, no vga out
You Can Try By Cleaning Out The Memories And Checking The Processor Is Placed Right In The Socket
Dec 25, 2008 | ASUS P5P800-MX Motherboard
SuperMicro H8DCE-O R Motherboard no video
did you plug up toe power to the video card, the problem seems to be that the video card is getting no power, if the power is hooked up properly to the video card, the your power supply is probably not powerful enough.
Dec 04, 2008 | SuperMicro H8DCE-O R Motherboard
SuperMicro H8DCE-Motherboard no video
Are you hooking up The 24 pin ATX J1B1 connector and the 8 pin processor power connector JBW1 ? Alot of guys don't realize that new AMD's get power from a special connector on the motherboard..If you don't have this connector on your power supply you will need to get one that does. Hope it is this easy.
Motherboard destroyed by lightning
I'm located in New Zealand and purchased a motherboard for my T135 from www.trademe.co.nz. Possibly www.ebay.com and other trading sites could be helpfull.
If its any help the motherboard I purchased was a Winfast core series 760GXK8MC-RS. That supports an AMD Socket 754 cpu.
It seems to have done the trick but by the looks of it after replacing the motherboard I will have to install a new operating system as the orignal Windows XP was an OEM version (which means that it was pre-installed on the hard drive) and the recovery discs won't work with the new motherboard installed.
Jul 10, 2008 | Acer Aspire T135 PC Desktop
No Display on screen.
If available, try using a different video card to see if it will POST. The only other thing I can think it might be is that the processor isn't seated correctly, or that it is seated correctly but you have too little, or too much thermal compound on the CPU.
Sep 15, 2006 | AOpen AX45-V (91.88I10.004) Motherboard
EliteGroup P4M800PRO-M Motherboard Logo
103 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
