Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Looking for the owners manual for my generator....
I have a Briggs and Stratten 10HP/305cc/5500 Watts
Model# BSV550-W. Does anyone know where I can download a free owners manual on the Internet? I would like to copy it and be able to print it. HELP...!
  • Anonymous Mar 15, 2014
    need spark number for a briggs and strattongas generator 5500 watt
    President:
  • 2,692 Answers
  • patience26 Aug 27, 2010
    THANK YOU SMITHBROTHER THE PAGE WAS UNDER REPAIR SO WILL HAVE TO LET YOU KNOW LATER PATIENCE26
I have a Briggs & Stratton 5500 watts generator that I hardly pull the rope for start, begins stuck then its loosen again and again gets too hard to pull, any suggestions please help
If the unit is older it could have heavy carbon in the cylinder heads, it could be a ring sticking and binding, do a compression test. Compression is high or mechanical binding.
Feb 24, 2015 | Briggs Stratton Portable Generator 305cc...
Why does troybilt generator engine keeps shutting off when throttle is moved from choke to run position?
Give it a shot of starting fluid. If it runs initially, then most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 05, 2014 | Briggs Stratton Portable Generator 305cc...
What is a rectifier
A rectifier is an electrical device that converts alternating current (AC), which periodically reverses direction, to direct current (DC), which flows in only one direction.
Mar 09, 2014 | Briggs Stratton Portable Generator 305cc...
Engine runs fast and slow
Take a spray of carb cleaner and clean the linkage mechanism from the governor to the carburetor and make sure they move with out sticking.
Dec 07, 2013 | Briggs Stratton Portable Generator 305cc...
After starting it it dies seconds later like it's out of gas
Check the oil viscosity and level, and also make sure the low oil pressure switch isn't the culprit
Nov 12, 2013 | Briggs Stratton Portable Generator 305cc...
Motor was loping i cleaned plug and filter now it runs like 3 min n quits
carburator needs to be cleaned,and put new fuel in the tank as well as a gas stable product
Jun 07, 2011 | Briggs Stratton Portable Generator 305cc...
No power output from Briggs & Stratton ProMax 7500E generator
You may have exciting field broken. Look for a fuse or wire break.
Jun 04, 2010 | Briggs Stratton Portable Generator 305cc...
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
886 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
