Error 5800 on Canon Pixma MP170
I have a Conon Pixma MP170 and have error 5800 appearing - I have tried cleaning 'Waste Ink' pads with tissue - iy has worked for a week or so but not any longer How do I remove and clean properly and re-set prniter ?
Solution #1 worked with my MP170 but it could be described more clearly, as follows:-
1. If the power is on, turn it off (press the on/off button).
2. Hold down the stop/reset button (red triangle in red circle).
3. Whilst still holding down the stop/reset button, hold down the on/off button.
4. Whilst still holding down the on/off button, release the stop/reset button.
5. Now press the stop/reset button twice, quickly.
6. Next release the on/off button.
7. Wait untill the LCD display shows “Canon idle” (this may take a few minutes).
8. Now push the stop/reset button 4 times in succession, quickly.
9. Press the on/off button twice, quickly.
10. Now press the on/off button to switch the power off.
11. Finally, press the on/off button to switch the power back on.
This sets the ink pad counter to zero, even though the pad still contains ink.
Remove ink from the pad, as follows:-
Open the lid of the printer to reveal the cartridge track and ink pad.
Winkle out the ink pad, using a pin or a small screwdriver or tweezers.
Wash the ink pad in clean water, squashing the pad to remove the ink.
Dry the clean pad by squashing it between sheets of kitchen paper.
Replace the pad, taking care to fit it between the alignment notches.
Posted on Apr 25, 2009
  • 679 Answers
1. Turn off printer.2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color.
3. let go button Stop/Reset, continuing to hold POWER.
4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons.
5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key)
6.turn off printer by POWER button, then turn on.
7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Posted on Jan 28, 2009
  • herman_maril Apr 18, 2011
    This is amazing! Thank you so much! I thought I'd have to buy a new printer. When I rang Canon customer support, I was told to unplug the machine for 30 minutes to restore factory settings, and if that didn't work, to send it for repairs. And obviously that wouldn't have been economical. And it's a time when I'm particularly short of cash - and I'd just bought 3 new ink cartridges, and would have lost the money for that. So Rochfixya has saved me a lot of time, trouble and money. Thanks again.
The problem here is the waste ink pads are full, these pads are located at the lock posistion to the far right where the units cartridge holder goes when you power down the unit and on start up. The way to solve this to to have the pads replaced, they are used to collect the waste ink the printer uses to clean itself when starting up, These pads usually take a long time to fill up, so either you do alot of printing or you hve used Non Canon inks or generic refill cartridges in the past, these are not good for your printer as some of these types of inks are either to thin or to thick and fill the pads up prematurely..Keep in mind to always use recommended guine ink cartridges you may save a little now with ink refill cartridges but in the long run your printer will eventually give out.
Jul 14, 2010 | Canon PIXMA MP170 All-In-One InkJet...
How to solve the problem of "Waste ink absorber is full", then show "check printer" & "5800" after continuing to use it for Canon MP150 Printer?
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp170
firstly download MPTOOL
Download here
Download manual guide how to use MPtool
download here
OK hope this can help
Jul 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
How do I empty the Canon Pixma waste ink (Pixma 170)
Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
Please if you happy call back and gave a vote
Feb 13, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Won't print error message 5b00 on screen. How can
5B00 is the waste ink absorber full message, only a Canon repair shop can reset the error code.
Jul 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Mp170 waste ink absorber full
The waste ink absorbers on this machine are under the print engine and cover the entire bottom of the printer. You have to have access to the diagnostic program on the printer to reset the error codes.
Jun 29, 2009 | Canon PIXMA MP170 All-In-One InkJet...
The waste ink collector/tank is nearly full
The ink collector should be found underneath where the cartridges normally rests. Put some tissue paper on the ink padand let it absorb the ink. You might have to repeat the procedure a few times to get rid of all the ink.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
The waste absorber is full ,Replace the pads
then if you still get the error,you can reset it by following the directions below.
(reset without replacing pads can cause damage)
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by pressing <--- or ---> then OK
Jan 20, 2009 | Canon Pixma MP450 All-In-One InkJet...
Waste ink pad full error message
plz check the website
Aug 04, 2008 | Canon PIXMA MP170 All-In-One InkJet...
1,899 people viewed this question
