Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
WD 63 At the beginning of the wash cycle, water leaks out of the powder drawer.
  • Corinthians6 Jan 12, 2009
    Thank you for trying. As yet the problem still exists.
  • Hotpoint Master
  • 3,463 Answers
Remove dispenser drawer from m/c, and thoroughly clean it and all accessories.Clean all residual build up of undesolved powder and conditioner in drawer compartment..
If it still leaks, then remove top cover, locate large black hose at bottom of dispenser, and give it a good squeeze to clear any possible blockage in the hose itself..
If still no better, could be due to exceptionally high water preesure forcing the water out of the drawer.
Turn cold water valve down a little to reduce pressure.
Plz rate my solution.
Thanks.
Posted on Jan 09, 2009
  • Blue Turbo Mar 11, 2011
    Thank you, worked a treat
Why is my lg wd 1049c frnt loader washing machine leaking from the lh top cnr between the top drawer panel and the main body panel every time the machine fills, i have checked the powder drawer and th
Remove the screws that attach the top panel at the back of the machine, slide the top backwards and remove the top panel.
Run the machine as per normal, but be careful as the electrics will now be exposed, you will be able to see where the water is leaking from and be able to repair/replace defective part.
Aug 11, 2016 | LG WM Washing Machines
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Simpson front loader washer leaking from front soap drawer on the spin and rinse cycle when filling
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Mar 10, 2013 | Washing Machines
I have a whirlpool wfs 1071aw and havent used washing liquid before only powder...cant find my manual and when I put the liquid where I would have put powder it leaks soap out of the dispenser onto the...
You should have a little divider in the soap drawer , it needs to be moved into a different position for liquid ( holds the liquid until the cycle begins)
Mar 15, 2011 | Washing Machines
Whirlpool front loader WF665/1 spilling water during cycle. Water is leaking from where the powder is deposited into the machine during the filling stage of the washing cycle. The machine will continue its...
that means that the water is leaking from the hows at the back of the detergent drawer.
This is not a difficult fix, however the washing machine must be taken apart to access the detergent hose and find the leak.
Always better to call a technician.
Nov 16, 2008 | LG WM2487H Front Load Washer
Water is leaking out of the washing powder drawer
the spray holes in the soap manifold are partially blocked and spraying at an angle. try to reduce the water flow pressure at the feed tap and clean the water holes in the soap tray manifold (above the tray).
Feb 16, 2008 | Whirlpool AWM8143 Front Load Washer
Water leaking (Aquarius 1200)
don't think using quick wash should make a difference as water intake is the same take drawer out and wash thoroughly especially the rinse compartment. if gunged up the water overflows the compartment and leaks down the front. otherwise, you may have a blockage in the hose from the drawer to the tub. take top off, remove this hose and clean disconnect from mains when you do this
Apr 01, 2007 | Hotpoint Aquarius WD63 Front Load...
Water leaking and dial spinning
unconnected faults. does water come out of drawer when filling? if so fault is a blockage in hose down to tub from drawer or drawer may need cleaning if fault happenns on rinse. fault on knob is broken inner knob and poss cam as well
Mar 14, 2007 | Zanussi FLA1201W Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
260 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
