Question about Motorola Mobility S805 Wireless Headset
Pairing Nokia N78 with Motorola S805
Hi - I am having problems pairing my new Motorola S805 bluetooth stereo headset with my nokia n78.
I can connect the S805 to my laptop for music and my blackberry for voice calls but when I pair with my N79 it connects.... then about 1 second later, it disconnects. The only thing I noticed is that when pairing it does not ask for the passcode.
I think there is an incompatibility problem but would be interested if anyone else has had similar problems.
Pair using the wired headset first and that will sort
Posted on Aug 21, 2009
N78
HI if your Nokia n78 mobile is locked to network provider .Then you can easily unlock it using sites like http://www.theunlockarena.com/nokia-n78/rs1wp9/ here they are rendering network unlock code for all mobile models at reliable cost .You first verify that whether they are rendering code for your country and network provider .If yes then pay for it and unlock your phone .
Jan 14, 2014 | Nokia Cell Phones
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
Jun 07, 2011 | Nokia Cell Phones
My nokia n78 lock
If you need to Unlock the Mobile from Network Lock,You can get the Unlock code at here
http://www.superunlockcodes.com/nokia-n78/rs12wp9/ and Unlock it.
Jan 25, 2011 | Nokia N78 Smartphone
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Nov 13, 2009 | Motorola Mobility S805 Wireless Headset
Nokia N78 Faceplate Cover...
Don't. N78 is not userfriendly when comes to dissassembly.
Aug 16, 2009 | Nokia N78 Smartphone
Nokia n78 will not turn on
hi thanks for using fixya!
Try the following options.
1. Turn off your mobile unit
2. Remove the sim card
3. Remove the battery
After you do all those, install them back again, and try to turn on the power. If you are experiencing the same problem. I suggest you should bring your phone to a service center to further check the error.
Regards!
May 03, 2009 | Nokia N78 Smartphone
N 78 Bluetooth unable to search new devices
Users have encountered a lot of issues, bugs and problems with Nokia N78, the first S60 device to support Feature Pack 2. If you are facing issues with your smartphone, here are a few tips to get your mobile phone back in business. + To restore your phone to the original factory default settings, press the Menu button, then go to Tools, Settings, General, Factory settings. Here you need to enter the lock code (generally 12345). After the reset, the device may take a longer time to power on.
+ To hard reset/format Nokia N78 (all data will be lost), follow the below mentioned steps:
1. Turn off the mobile phone.
2. Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
3. While holding these three buttons, press the power button to switch on the device.
4. Release your fingers when the screen displays the Nokia Logo and the language selection menu further.
pls reset the device fully and if no help pls update the OS dont worry it is tested 100% may be in ur case the problem solves PLS RATE ME FIXYA if u like
Mar 16, 2009 | Nokia N78 Smartphone
Motorola Mobility S805 Wireless Headset Logo
274 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
