Question about Whirlpool GH4155XP Microwave Oven
No Power, Outlet is Fine
The house breaker triggered for this area. After resetting there is no power on the microwave but the outlet is fine. I have seen posts about looking at the Thermal fuse in the back. Is it accessiable without having to take the microwave down from the wall? If I have to take it down how do I do that?
All thoughts are welcome.
    Problem Solver:
  • 11 Answers
Most microwave fuses should be near the front. At least GE's are. You shouldn't have to take it down. unscrew th fan grill and it should be right behind it.
Posted on Jan 28, 2009
Frigidaire FMV158FMB power issue
Sounds like the door latch switch is broken and shorting out.
Feb 20, 2014 | Frigidaire Microwave Ovens
How do I set Clock?
Disconnect the microwave from the power source while the power is still out. If the microwave is a built-in, turn off the circuit breaker. Otherwise, unplug the microwave from the wall outlet. This prevents a power surge from damaging the magnetron tube when the power is restored.Turn on the circuit breaker or plug the microwave into the outlet only when you are sure that the power is permanently restored. If there are still storms in the area, the power may be disrupted again. Reset the clock on the microwave. Microwaves vary slightly on how to set the clock, but usually there is a clock button you press. Use the number pad to input the correct time and press the clock button again to set it. Test the microwave by heating some water to ensure that it is still in good operating condition.
Jun 20, 2012 | Emerson Fans MW8995B Microwave Oven
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Microwave pops hose breakers. Microwave gets
The problem is in the microwave oven, you have a short in the power supply or it could be a defective door switch, either way the unit needs to be checked out.
Feb 27, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
The microwave does not react what so ever. Checked the fuse and its fine, what could be the problem? please help
Is there power at the outlet? You say you checked the fuse ... is that the one inside the machine? Is the outlet protected by a GFI (reset for a GFI is on the GFI)? A GFI looks like a ordinary outlet but is very sensitive to electrical irregularities. Your circuit breaker may be on or your power panel fuse may be fine and the fuse inside your oven may be fine. If the GFI is popped, you have no power.
Try some other electrical device in the outlet. Does it work? Try an extension cord from a known hot outlet?
Beyond these tips, you may need professional help with this.
Thanks for your interest in FixYa.com
Jan 22, 2010 | LG LMV1630ST Microwave Oven
We had an power outage and lost power for a few hours everything came back on but the microwave. I checked the outlet and checked the fuse still nothing. Is there anything that can be fixed?
Hello if you have no power at the outlet, you may have saved your microwave. If the outlet is dead go to your house electrical panel and reset the breaker or replace the fuse. if the outlet is live and the microwave still won't power on you will have to choose between repair and replacement. Definitely get an estimate before agreeing to a repair as microwaves are very inexpensive today compared to even a couple of years ago.
Nov 23, 2009 | Emerson MW8108P Microwave Oven
Lg micorwave, lam1180st refridgerator and microwave were plugged into the same outlet. i heard a loud pop. circuit breaker popped. i reset and the frige works fine. Microwave does not have power. the...
It is possible that the interconnection link(s) between the two sockets in the duplex outlet have blown apart. Turn off power at the electrical panel for this circuit, remove the outlet from it's box, and check the interlink on both sides. If obviously burned, replace the socket. A better option is to run another duplex cable from the breaker box to the outlet from a new breaker, cut the interconnections on the new socket, and wire the new cable to the isolated part of the socket. This supplies full power to each half and allows both units to run at the same time.
Oct 19, 2009 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
Our Emerson microwave died and I bought a new one. Plugged it into the same socket and it immediately shorted out and died. After the new microwave died I plugged a blender into the same receptacle and it...
I believe you have a bad circuit breaker or fuse. If you have a delay fuse contrilling this circuit, that would explain the spotty availability of power to the outlet. Also, a faulty circuit breaker can operate in an irregular way, as you describe.
A microwave oven requires a lot of power, relatively speaking. If your microwave is a 1200 watt model, for example it draws 12 amps of power, which could well be almost all of the power available at that outlet, providing that other appliances were not also drawing power from that circuit at the same time.
I can assist you further, but if this information is all you need to proceed that is fine too. Get back if you need more assistance.
Jul 02, 2009 | Microwave Ovens
GE Spacesaver microwave trips the circuit breaker
Since power = voltage X current, 1.58kW / 120VAC = 13.166A
So this unit should be fine on a 15A breaker unless the breaker is bad, the wiring or a connection is loose somewhere between the breaker and the microwave, or the microwave's magnetron or high voltage transformer are failing and drawing extra current.
Microwaves should really be on the own separate breaker if at all possible. Plus, the more a breaker trips, the more work out it gets.
Have you measured the voltage at the outlet? If that's off, current and power will be affected. It should be about 110-125VAC.
A good power test for outlet and wiring integrity is a toaster, toaster oven, or hair dryer rated at about 1500 watts.
If it doesn't run and heat steadily, then there may be a problem with the house wiring or breaker.
If it passes this test, the problem is likely in the microwave.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 09, 2008 | GE JVM1190 Microwave Oven
Whirlpool GH4155XP Microwave Oven Logo
104 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Gerry Harvey
Gerry Harvey
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
