Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
E44W46LCD Lamp Timer Reset
I just replaced the lamp in my TV. I am unable to turn the TV back on (i believe the timer has reached it's max, therefore not letting me turn it back on, so i cannot access the menu). Is there any way to do this w/o the remote. I have std remote, it does not have the "?" button it tells me to push to reset timer.
To reset the lamp timer, hold the "enter" button on the tv and the "mute" button on the remote at the same time. Once the menu pops up, hit the right arrow on the remote and confirm the reset.
I would guess that's it's a little too late for this answer now, but for future reference... ;-)
Posted on Apr 17, 2009
  • 30 Answers
Natron_44 has the correct procedure, it worked for me.
Hold mute on the remote then hold the enter button on the TV while still holding mute. After several seconds, a menu will pop up. Press the 'right' arrow on the remote and press the center button to reset.
Of course, this will only work if your TV turns on and you see picture.
Posted on Apr 21, 2009
I was told only the service people can reset this timer---we just changed our bulb and it is still orange---we just left it--not worth paying for someone to come out and reset it
Posted on Jan 19, 2009
    Problem Solver:
  • 8 Answers
A special service remote must be used to reset the lamp timer. If the set did not come on before you changed the lamp then the lamp is not the problem. If it was working before you changed the lamp make sure the lamp is seated correctly also the lamp door must be on.
Posted on Jan 30, 2009
How to reset lamp timer on panasonic pt-50dl54j
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 07, 2017 | Panasonic Televison & Video
How to reset tv lamp on mitsubishi wd-65831
RESET LAMP TIMER
    • 1 Turn on the television after replacing your television's projection lamp with a new unit. If a dialog box displays on the screen asking you to reset the lamp timer, use your remote control's "Arrow" buttons, highlight "Yes" and press "Enter." If the dialog box does not appear on your screen after turning your television on, proceed to the next steps.
    • 2 Turn on the television, then press the "Menu" button on your control. Navigate to the "Setup" menu, press "Enter" and choose "Low Powericon1.png" from the menu options displayed on the screen. Press the "Exit" button on your remote control and turn off the television.
    • 3 Repeat the first step to reset your television's lamp timer. If your television screen is unable to produce a picture after replacing the projection lamp, press the "<", ">" and "Power" buttons on your remote control at the same timeicon1.png to reset the lamp timer.
Read more: http://www.ehow.com/how_7358147_reset-lamp-timer-mitsubishi-65731.html#ixzz33n0pJu2S
Jun 05, 2014 | Panasonic Televison & Video
Tv image will not show , it turns off it says ... something about the lamp inside the tvneed to be replaced?
The lamp timer on your unit has reached the max hours. it needs to be reset. There should be a reset feature in the menu. You should replace the lamp. It will brighten up your picture too. It must be done soon as once the timer reaches a limit your unit will not turn on at all. Check your manual for proper lamp type and replacement proceedure.
Feb 27, 2010 | Panasonic Televison & Video
I turn the tv on it stay on for one second then it goes off thats when the lamp button comes on its red. then the red light comes on and it stays on although the tv is off the red lamp light is still on
Your lamp timer may be maxed out which means you should change the lamp and reset the lamp timer. When the timer max's out it won't turn on till it is reset.
Feb 09, 2010 | Mitsubishi WD62327 TV
I have a zenith e44w46lcd tv, while watching it, it turned off and now will not turn back on again. Green light flashes for a bit then goes back to red. Also lamp light is on orange. Do I need to replace...
More then likely your lamp is faulty, you can replace this lamp urself, but on zenith models the lamp comes as a bulb only, you will have to change the lamp and use your original housing. Also lamp timer will have to be reset. The only reason you might need a repair man is to go into factory mode and reset lamp timer. But if you are mechnically incline you can swap the lamps yourself..
Thanks any questions email me at -
Delhielectronics@live.com
Sep 27, 2009 | Zenith E44W46LCD 44" Rear Projection...
Reseting the end of lamp life indicator
Hold down mute button on remote and enter on TV
at the same time for a few seconds, you should get
a screen promt asking if you want to reset the timer
for the lamp.
Mar 31, 2009 | Zenith E44W46LCD 44" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Lamp reset
The correct way to reset the lamp timer on that unit is to hold the menu key on the remote and push the enter key on the front of the TV at the same time. Hold them (it's about 9 or 10 seconds) and then a screen comes up asking if you would like to reset the lamp timer. That will reset the time but if your problem is a dark picture that's probably not going to fix that.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith Lamp Light on
When the lamp is replaced the lamp timer must be reset. The timer is set for just so many hours and then the warning lamp is illuminated. The only way to reset the lamp that I am aware of is with a zenith programmer remote. Perhaps you can find a local lg/zen service center to allow you to use a programmer and instruct you on resetting the timer.
Jan 29, 2008 | Zenith E44W46LCD 44" Rear Projection...
Lamp light
If you still need code i have it at shop i am home right If i rember right you must reset lamp Timer to Tell tv that it old lamp has been replaced with new code is 9,8,7,6, ect...........
Jan 17, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
1,054 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
