Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Door wont open on Whirlpool washer cabrio display says du
Washer had load out of balance, when i hit pause to open door and redistribute the load I got error code and door wont open even if I unplug and replug back in
  • 15,935 Answers
To Access/replace the switch:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
What does code uL mean. this comes on in the drain spin cycle
Hi, a UL error code means a load not balanced. The washer is running a load-balance correction routine. Please allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.
Aug 14, 2016 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Wont start.buzzes.unplug to turn off
Possible unbalanced load in the washer. I have found this to be the case in other types of top load washers. Just redistribute the load the try again. If this works, washer is doing what it needs to do to keep from spinning madly out of control and extending its life!
Feb 25, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
What is DU blinking on a Whirlpool Cabrio washer mean?
'DU' stands for Door Unlock Error. There is likely to be a problem with either the door solenoid/lock or the 'door open/closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer has an error message "uL", the washer is full of clothes and water; but won't do anything...what should I try?
Unbalanced load uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load.
Mar 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does code F mean
F is part of a system fault code. There should be additional characters (numbers) in addition to the F.
Here's what I get from a Cabrio Owner's Manual if there are numbers after the F:
F## code (F-type error code) appears in display
System error code. Press START/PAUSE once to clear the code. Then press START/PAUSE again to restart washer. If code appears again, call for service.
I called Whirlpool at 1-800-442-1111, and according to customer support the manufacturer intentionally no longer provides descriptions for F codes (though there are still a few owners manuals that will describe something like F21 = Long Drain). Check to see if your owner's manual provides any F code help in the troubleshooting section.
Generally, what I was told is that F codes indicate customers need help from a technician. Not always completely true, and really not very helpful--especially if you want to attempt to avoid scheduling service.
Since there are numerous F## codes, please provide the specific code number if you desire further assistance.
Here are letter codes Whirlpool provided in the owners manual (copying from a PDF works poorly):
oL (overloaded)
appears in display
Load too large. If an overload is detected, the washer will drain any water and
detergent in the washer. Remove several items and add HE
detergent. Close lid and press START/PAUSE.
uL (unbalanced load)
appears in display
Load not balanced. The washer is
routine.
Allow the machine to continue. If the dial is flashing and the
machine has stopped, redistribute the load, close the lid, and
press START/PAUSE.
LF (too long to fill)
appears in display
Washer taking too long to fill.
Drain extends more than
4.5" (114 mm) into standpipe.
Check plumbing for correct drain hose installation. Use drain
hose form and attach securely to drainpipe or tub. Do not tape
over drain opening. See "Installation Instructions".
Ld (too long to drain
water ) appears in
display
Washer taking too long to drain
water. Drain extends more than
over drain opening.
Lower drain hose if the end is higher than 96" (2.4 m) above
the floor. Remove any clogs from drain hose. See "Installation
Instructions".
etc...etc...
Jan 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
On my Cabrio, the washer goes through all of the cycles fine until it gets to the final spin. No matter the size of the load, I get a "ul" code. I can move the items in the washer around but it contines...
Hi
Thanks for using FixYa. ULis displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio washer is blinking uL HELP!
Hi. uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalanced the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load.
Aug 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
