Question about Mercury P4VM800M7 Motherboard
Max hard disk support
Sir,
please tell me that mercury 865 motherboard can support which kind of hard disk and with max how much is the memory limit of hard disk it can support.
  • 43 Answers
Hello. the motherboard supprts this
Max Supported RAM - 3gig
Audio Output - Sound Card • 5.1 Channels • Line Out
Video Interface - AGP 8x
On Board Graphic Processor - Intel Extreme Graphic
Expansion Slots - AGP x8 x 1 • PCI x 3 • CNR x 1
don't forgett to rate. Ty
Posted on Jan 09, 2009
Sir a problem in my mercury p4vm800m7 board just a buzer sound coming and processor fand running
The buzzer indicates a memory problem. Disconnect all disks, take out the memory and clean its contacts with an eraser, put it back in and try again. If it fails try another memory module. If it fails again then the board has died, time for a new one.
Aug 28, 2011 | Mercury P4VM800M7 Motherboard
Sir i changed the ram for my mercury 865 after replaceing its not getting started and then i try with the old ram same prob plz help me ali....
hi friend, i think your new ram created a problem with your motherboard. remove your motherboard battery for 15 minutes. then, place it and after it you go for your old RAM. if it again create a problem.so, go for nearest service center. they will surly fix problem.
Regards: Rakesh
Feb 05, 2011 | Mercury Computers & Internet
How much Hard disk my motherboard D845GVSR will support.
There's not really a limit to how big a harddisk you can support. The only thing that can restrict you is the connection, because, for obvious reasons, you can't connect a SATA disk to an old IDE board, but it seems like you're aware of that.
You can just buy any SATA HDD you want!
May 13, 2009 | Intel D845GVSR Motherboard
I want install windows98 with xp in a computer
HEllo,
if you know the installation of winxp and win98 then it is possible to create a system with mercury board with 98 and xp.
firstly you install win xp in your computer. it's automatically located in c drive. then you intall win 98 custom install and then choose the installation directory of another drive like d. you use any boot manager to boot the pc with win98 and winxp. i don't tell you the installation process step by step. so don't mind.
thanking you
ramesh
Nov 14, 2008 | Intel 865 S478 8X 10/100 Lan Motherboard
Maximum HARDDISK CAPACITY FOR Intel 865GV motherboard
Yes, your board will support 320gb. I am not aware of a limit to how many gigabytes you can have per computer. I currently have 1.5 terabytes. 1500gb.
Apr 22, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Vertual memory low
The applications you are running are taking not only more memory than the system has (SDRAM, DDR or such) but more memory than can reasonably be swapped out to the hard drive (which is making it noisier and overused as well!)
It happens to everyone.
The solution is to max out the real memory your system has (the limit is set by the CPU and motherboard models in use) so that it doesn't have to use the disk; but I find on some systems that even then, I have to scale back what applications I have going. It is impossible to efficiently browse 100 web pages (in tabs, for example) and also run spreadsheets, watch animation, etc.; especially in Windows (any version.) If you choose Linux or another OS and select applications carefully for efficient use of memory, you may be able to do more with the same machine. It depends on what you demand be done, of course; but if you learn shells like bash and tcsh you can certainly get more done.
In an extension of your problem to a general case; the solution is utility computing or virtualization, where you farm your computing out to a computer someplace, adequate to do the job, and thus having a setup specialized wherever you are is moot; it has been done once.
Your last paragraph made little sense and you have not indicated what kind of system you have, so it is hard to advise on that. What I do know is that hard drives fail over time, and that you need to keep them cool (26 degrees C.;) very clean and dry; and isolated from shock.
I would have to do a lot to make that happen in equatorial climes. The good news is that DVD drives like similar care and that you don't have to use metal to conduct heat to the evaporator. Just mount the drives with some chunky ceramic (or metal) heatsinks and isolate it with rubber mounting or bungees. More good news: Drives that are new and not about to fail are nearly silent.
I also think it would be instructive for you to try a LiveCD; that is an instance of an OS which runs from the CD or DVD drive and never touches the hard drive except as told, makes copying files from your old disk easy, and gives a chance to try all kinds of OS. Knoppix is probably the oldest one. (See also OSNews.com, OS Galaxy, old issues of LWN.net (which are free,) etc.)
Solid-state drives are a good option for some things too.
Feb 22, 2008 | Audio Players & Recorders
Mercury P4VM800M7 Motherboard Logo
104 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
