Question about Samsung 172X (Silver) 17" LCD Monitor
172x switches off during operation
Hello ptkent
comming back to the Samsung 172x problems, which all seamed to appear about 4 years after purchase (in 2008 for most users).
My LCD also switches off during operation after about one to two hours. The green status LED switches off and the screen switches off too.
When switching the screen off and then on again the status LED is on for 2 seconds and the goes off again without the screen showing anything.
If you remove power you can use the LCD again after about one hour.
I love my LCD and would be thankful for directions.
Thank you for your answer to tim-fuss@gmx.net
JULIANFIX
  • 975 Answers
SOURCE: Screen goes black and have to restart
looks like you have a DRY SOLDER or COLD solder , if your handy with tools , you have to open monitor and check the PC BOARD, specially where some transformer is located look around that area for some burnt spot , re solder it , and try it again , should be working properly , hope this helps AJ
Posted on May 02, 2008
  • 24 Answers
SOURCE: Screen goes black after 2 seconds
Simplest solution may be the screen resolution settings are set higher than the monitor's capabilities. Try lowering the screen resolution and refresh rate in the display properties or try booting to safe mode (press F8 when the Windows splash screen first appears) and see if the LCD will display the windows desktop. It that works, check your video drivers and the screen resolution and refresh rate settings.
If the monitor has the problem in safe mode and/or if lowering the screen resolution and refresh rate don't help then I suspect the a problem similar to one some Dell 17inch LCDs have. On the Dells It is usually caused by a defective voltage regulator transistor in the backlight inverter circuit. Troubleshooting that problem should only be attempted if you have experience at repairing electronic circuitry since it will involve testing individual components and soldering.
Posted on Jun 15, 2008
GregL
  • 49 Answers
SOURCE: screen goes blank after 2 seconds
Do you have the video set to a range that this display cannot handle? Try rebooting into Safe Mode and set the resolution down to 800x600 or 1024x768 and see if it that will get you back. If so, then look up the specs of the display and set it no higher than it's max.
If it physicaly powers OFF, then you probably have a power issue.
Posted on Jan 20, 2009
  • 181 Answers
SOURCE: Samsung 930BF Problem
try the monitor on a friends computer or family menbers computer first as it may be your grafic card at fault.
Posted on Jun 01, 2009
  • 1684 Answers
SOURCE: No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 22, 2009
Cooling problem in my Samsung rt29cdlb1/xtl
Hallo
Low humidity in your area set the thermostat colder or its the thermostat not switching of at the right temp.
Regards.
Jun 21, 2016 | Samsung Refrigerators
Screen marks on my samsung lcd tv.
Sorry not a solution just confirmation of similar fault on a Samsung 32" . I to have this problem which appears to be getting worse . started with 1 mark and has now spread to about 20% of the screen albiet numerous marks. It appeared after 18months to 2 years after purchase in 2006 so now 4 years old. I've accepted there's nothing to be done and out of warranty. Problem is purchase a new set Samsung or another. But will I have the same problem 2 years after??
Oct 30, 2009 | Televison & Video
Samsung SyncMaster 213T - DIM DISPLAY
I would follow the self-test below. If you see the same issue in the test screen then your monitor has lost it's sync and would need a board replaced.
If it dosn't appear during the test, then you might want to test it on another PC.
Self-Test Feature Check
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after using the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jul 22, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Kenmore Elite Trio model 795.7757
Hello fergust
Welcome to Fixya,
You said, I have just purchased this unit and switch it on.After some 3 minutes error message appeared on the front door screen . Message ---- ER CF Neither fridge,freezer or ice maker are working. What is the problem.
Did you turn the refrigerator and freezer on to the proper cooling adjustments as in the user manual?
Is the ice maker hooked up to the water line and in the on position?
Did you use the free help line if you are doing it your elf?
While I look it up, you can try to reset the system by plugging the fridge for 5 minutes, or if you can not reach the plug, then throw the breaker for 5 minutes.
Not less than 3 minutes. That is why I sad, 5minutes.
Usually this will do it! let me know as I look up the error codes.
Please remember to leave a rating!!!!!
Call this number for all Kenmore questions 1-800-4-MY-HOME
One Year Limited Warranty
When installed, operated and maintained according to all instructions supplied with the product, if this appliance fails
due to a defect in material or workmanship within one year from the date of purchase, call 1-800-4-MY-HOME to arrange for free repair.
Let me know how it goes!
Bless You.
Huuum
Sep 08, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
My LCD Samsung Sync Master 172x Blank Screeen
Hi Yanss1971,
May i know, what's the power led light status? Red, Green, Orange, Blinking or Off? If you need more info on lcd monitor repair please visit this site as reference: http://fastrepairguide.com/p/lcd-monitor-repair/
kent
May 09, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Kenmore 580-51650000 dehumidifier
It is more than likely the compressor is not running, only the fan.
It seams that the humidity sensor is flaky on these units. You can,
operate the unit, by opening up the dehumidifier and unplug the sensor from the main board. The unit will cycle on and off and remove the water from the air.....good luck
Apr 21, 2008 | Kenmore 54501 Dehumidifier
LCD Monitor SAMSUNG Syncmaster 172x
change the potentiometre(three broches) and adjust it.
you find it near circuits which switch on the lampes (card has smalls tranformers)
good luck,Mustapha(Casablanca,
Morocco)
Apr 08, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Double image on letters for progran guide, 12" green line during perfect focus and on start up componet one need to be re-booted a few times to acquire video
Best advice run as fast as you can to the nearest Repair Shop that does samsung warranty- /// quit calling circuit city it seems like they could care less if your set is fixed or not bad business,first of all those double images you are seeing means you have convergence going out repair cost with out warranty is 350.00 and up to as much as 560.00
Jan 19, 2008 | Samsung HCN529W 52" Rear Projection...
Samsung 172X (Silver) 17" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
